Post by muttsnuts on Feb 9, 2013 17:06:44 GMT 1
Ok, some of you might have seen my posting about trying to get better mid range on my 350LC, as part of this quest, I decided to try a set of Banhsee coils from Norbo.
So I've just done a back to back comparison of the Banhsee coilds versus the standard 4L0 coils.
My bike was baselined on the dyno and the carburation was allsorted out as best we could, to summarise the bike was making 46BHP in pretty much standard trim, but had a small flat spot around 5k to 6k, even after sorting out the carburation as best we could.
Next I fitted the banshee coils and 3 things became apparant very quickly.
1. The bike starts much easier 2. Throttle response is much crisper and quicker 3. The dyno run provide that pretty much throughout the whole rev range the bike was making 1BHP more.
Now it may not sound much 1BHP, but when you ride the bike you can definately feel the difference and the mid range flat spot hs all but gone now and that is down to carburation anyway.
So to summarise, is it worth buying the banhsee coils and fitting them, well I'd have to say a big YES, not only for the extra gee gee you get but alos because the throttle response is so much better.
Hopefully this will help others if they are pondering, new Banhsee coils versus 30+yr coils, erm, no contest in my eyes now
Next, to fit some KR1S carbs to see how that affects the bike, watch this space
Post by robslc on Feb 9, 2013 17:10:38 GMT 1
Anyone got any pics of the banshee coils, im going to try a Dyna coil myself & will d a dyno run aswell
Post by muttsnuts on Feb 9, 2013 17:12:15 GMT 1
Post by marsbar350 on Feb 9, 2013 17:34:46 GMT 1
good work this could be put in the tech section as a sticky bracket fitment wiring it up etc
Post by muzz350 on Feb 9, 2013 18:26:29 GMT 1
I hope there are plenty of these coils available as it looks like a good simple mod.
Post by marsbar350 on Feb 9, 2013 19:20:22 GMT 1
i was at norbos when they were delivered in 3 big boxes and i mean big!! conservatively he has 400
Post by Bozzy on Feb 9, 2013 21:32:12 GMT 1
Has anyone tried the on a pv yet?
Post by Denzil on Feb 9, 2013 22:47:53 GMT 1
Hi, as Butchers has said Andymarsbar sold them to me as Mick rdlclazy didn't want them anymore ha ha. Anyway in comparison to the standard N2 coil the Banshee coils generate a spark about 2 mm and you can here it cracking. The old coil you can barely see it. The bike has had a full nut n bolt rebuild and is at the local motorcyclist to have the carb fine tuned and an mot. Pictures will be posted when it's ready for the road. Got some pictures of the coils fitted and will show shortly. But well worth getting some as the benefits do seem huge. Denzil
Post by raven13 on Feb 9, 2013 23:40:27 GMT 1
I read somewere that these could also be an upgrade for the 125lc as well (using one coil) even if they only give 0.5 hp on the 125 thats almost 5% more power.
Post by Deleted on Feb 10, 2013 0:00:46 GMT 1
No reason why you can't fit just one to your 125 raven. Find someone to share a pair of them
Post by raven13 on Feb 10, 2013 0:14:28 GMT 1
i'll buy a pair. got 2 bikes
Post by billyboy on Feb 10, 2013 0:53:17 GMT 1
always thought the sparks on my valves were weak as piss , has anybody fitted them too a valve ?
Post by Bozzy on Feb 10, 2013 1:16:55 GMT 1
always thought the sparks on my valves were weak as piss , has anybody fitted them too a valve ? Billyboy think you missed my earlier post asking same question...appears to me that all having done this are stating positive results so it's on my list to do! If the bikes 25+ years old and 15 k+ extg coils must be past their best...
Post by Deleted on Feb 10, 2013 1:18:11 GMT 1
always thought the sparks on my valves were weak as piss , has anybody fitted them too a valve ? yeah denzil has put them on a valve with excellent results got to remember the old coils are 30 plus years old so the copper will now have a higher electrical resistance resulting in a weaker spark. think of it as, banshee coils = you swimming in water old coil, you swimming in mud
Post by flames on Feb 10, 2013 10:51:02 GMT 1
always thought the sparks on my valves were weak as piss , has anybody fitted them too a valve ? yeah denzil has put them on a valve with excellent results got to remember the old coils are 30 plus years old so the copper will now have a higher electrical resistance resulting in a weaker spark. think of it as, banshee coils = you swimming in water old coil, you swimming in mud when i swim,i sink.do they come with a rubber ring? ooer missus.
Post by billyboy on Feb 10, 2013 14:38:07 GMT 1
ok cheers all ,somink else to go on the ever increasing list then
horace
Post by horace on Feb 10, 2013 17:45:49 GMT 1
I've used a dyno coil on my rd400 ,the two wires that connect to the coil from the loom are different colours does it make any difference which goes on to each coil connection ,bike works fine but that could be down to luck!
Post by nikfubar on Feb 10, 2013 17:57:08 GMT 1
I've used a dyno coil on my rd400 ,the two wires that connect to the coil from the loom are different colours does it make any difference which goes on to each coil connection ,bike works fine but that could be down to luck! If you mean one of these www.dynatekuk.com/sport_bikes_ignition_coils.htmlThen yes you were lucky, it does matter which wire goes where. If you want a good coil these are the best
Post by flames on Feb 10, 2013 20:34:47 GMT 1
i got a dyna for mine.any ideas which wire goes where? havent fitted mine yet luckily.good thing to,i didnt realise it matterd which way round they go.
Post by muttsnuts on Feb 10, 2013 21:41:20 GMT 1
depends on the model of the RD400, if its a C or D then it does matter, if its an E/F it doesn't as they are electronic ignition and fire on the pickups on the flywheel and not via the points system, which is handed !
HTH
Post by bryan on Feb 10, 2013 23:28:46 GMT 1
fitted a Dyna minature coil on the LCYPVS.
Post by marsbar350 on Feb 10, 2013 23:32:50 GMT 1
looks good bryan straight plug and play
Post by steelerd on Feb 10, 2013 23:35:01 GMT 1
looks smart that dyna one how do the banshee ones fit can you stil run a coil cover?
Post by bryan on Feb 10, 2013 23:35:28 GMT 1
if you get the latched spade terminals, just remove the white plug from the origanal coil and make a small loom as in the pic with a bit of orange and black wire and black tube, and it dose. ;D Comes with no wires or HT lead, but has 2 straight and 2 90deg ends, just buy copper HT lead as its loads cheaper than the ones they sell. Starts so easy it ant real.
Post by marsbar350 on Feb 10, 2013 23:39:29 GMT 1
fits on original mountings norbos need a c.s.e in metalwork to fit ;D
Post by bryan on Feb 10, 2013 23:53:17 GMT 1
has long slots, fits standard holes and cover fits as in pic, the minature coil is DC-9 and 40,00 volts and is alot easyer to fit to standard LC fitting than the bigger normal Dyna coils, DC11 I think they sent first. www.dynatekuk.com/accessories_dyna_coils.htmlI MAD A MISTAKE ABOVE AND GOT THE COIL NUMBERS ROUND THE WRONG WAY, MINATURE COIL IS DC11 AND THE OLDER STYLE COIL WITH ANGLED OUTPUTS ARE DC9s. SORRY
Post by jollyjoiner on Feb 11, 2013 16:26:40 GMT 1
I've just picked up a pair of banshee coils from Norbo with a few more items, just need to knock up a couple of brackets and get them fitted. Mind you i'll not be trying them yet as i've not got my casings back from blasters yet and then need to rebuild the engine
Post by Norbo on Feb 11, 2013 19:03:23 GMT 1
and ofcourse my coils are only £40 and not £147 so i think a bargen for what they do
Post by Haggler on Feb 11, 2013 19:14:45 GMT 1
Summut else to save for then, I'm building a bit of a shopping list for Norbo, but trouble is I'm not building the bank balance to pay for it , that'll be a wish list then lol
Post by billyboy on Feb 11, 2013 23:24:54 GMT 1
sorry if i missed this one ,but do they come with the ht leads ? or do you fit your own to them ?
