Post by Roofmonster on Mar 2, 2013 18:19:04 GMT 1
Removed the forks and replaced the seals on my LC. Incredibly all the bolts came undone, including the bolts in the fork tubes that hold the dampers, not 1 clip pinged off, never to be found again. Both seals came out without a struggle, both new ones went in and seated properly without a fight. I remembered to put the spacers in first. Both the fork plugs went in first time and again the clips went into their groves without flying across the garage and disappearing.The forks went back into the yokes no problem and the pinch bolts done up ok. I was so surprised it went so easily, I am wondering if I forgot anything! (I'm sure I put the springs in!)
Post by marsbar350 on Mar 2, 2013 18:42:31 GMT 1
all i did was 60 miles ;D ;D ;D cramp in both hips :onearly crashed the fooker nice goldy tint to the headers
Post by wonkywheel on Mar 2, 2013 19:24:20 GMT 1
30 miles of fun ;D
Post by ste0070 on Mar 2, 2013 19:38:47 GMT 1
Offered up a different rear wheel, an rs125 should go straight in with the 20mm spindle as the current one only 15mm, happy dayz ;D Attachments:
Post by Delbert on Mar 2, 2013 19:43:48 GMT 1
Adjusted & lubed the chain ,, then the mandatory test drive !!
artie
Post by artie on Mar 3, 2013 11:14:06 GMT 1
Run up the road(first time start up since the first week in Jan)oil change,filled up with gas and 2stroke,just needs a fettle and cable lube and we,re good to go,still a bit of salt on the roads atm though.
Post by crash on Mar 3, 2013 11:43:05 GMT 1
painted me rear wheel while sun was out
Post by oldelsieboy on Mar 3, 2013 17:31:48 GMT 1
Started up the TZ rep, dragged it out the garage & took a few pics ;D
OEB
Post by Roofmonster on Mar 3, 2013 17:35:33 GMT 1
Removed the rear shocker.
Post by copper99 on Mar 3, 2013 17:56:35 GMT 1
all i did was 60 miles ;D ;D ;D cramp in both hips :onearly crashed the fooker nice goldy tint to the headers Stunning mate...
Post by raven13 on Mar 3, 2013 19:04:20 GMT 1
rode it to work and back. :-)
Post by flames on Mar 3, 2013 19:13:21 GMT 1
fitted fuel tap repair kit....fuel leak sorted.fitted new clutch pushrod and seal...oil leak sorted.took for test ride......water seeping from head gasket,retorqued to 25lbs ft......slight seep,re torqued to 28lb ft......slight seep,realize torque rench not too clever,so went for ride to my mates to use his posh one.re torque with good torque rench......then realise seep is coming from thermostat housing and running down....twonk!!! tighten housing......no more leaks...yipee.even managed a slight power wheelie before clutch slip kicked in......it never ends....
nearly forgot,fitted new plugs and caps. thanks norbo for supplying all parts fitted,and as always,the very speedy delivery.
Post by scoobytoo on Mar 3, 2013 20:09:15 GMT 1
At last refitted my master cylinder and bled the front brake, now it's time for an MOT after spending 4 years to get Elsie this far
Post by nelley9 on Mar 3, 2013 20:27:36 GMT 1
Put my gear clusters in my bottom case, and put new water pump seal + bearing in the clutch cover..
Post by sidney on Mar 3, 2013 21:24:54 GMT 1
fitted fuel tap repair kit....fuel leak sorted.fitted new clutch pushrod and seal...oil leak sorted.took for test ride......water seeping from head gasket,retorqued to 25lbs ft......slight seep,re torqued to 28lb ft......slight seep,realize torque rench not too clever,so went for ride to my mates to use his posh one.re torque with good torque rench......then realise seep is coming from thermostat housing and running down....twonk!!! tighten housing......no more leaks...yipee.even managed a slight power wheelie before clutch slip kicked in......it never ends.... nearly forgot,fitted new plugs and caps. when mine is ready mate well have to meet up ,i hope to be on the road in april !as were both in norfolk ! ;D thanks norbo for supplying all parts fitted,and as always,the very speedy delivery. when mine is ready mate well have to meet up ,i hope to be on the road in april !as were both in norfolk !
Post by Oliver31 on Mar 3, 2013 21:42:50 GMT 1
taken a Pic Attachments:
Post by Oliver31 on Mar 3, 2013 21:50:56 GMT 1
And another one Attachments:
Post by Deleted on Mar 5, 2013 5:26:27 GMT 1
Very nice, Sausages... very nice indeed! I finally started to put it back together. Well, I put the steering head back on with new bearings.
Post by flames on Mar 5, 2013 22:09:39 GMT 1
when mine is ready mate well have to meet up ,i hope to be on the road in april !as were both in norfolk ! ye,deffo dude.
Post by flames on Mar 5, 2013 22:13:34 GMT 1
if that bike were mine,i would be permanantly walking round with spoof in me pants!!!!!
Post by raven13 on Mar 5, 2013 22:15:31 GMT 1
bought some carbon reeds for her.
Post by bryan on Mar 6, 2013 0:27:34 GMT 1
nothing again!
Post by speedysquires on Mar 6, 2013 1:15:30 GMT 1
Removed the fuel tap and fitted new seals, then fitted the Nikon pipes....
r1olly
Post by r1olly on Mar 6, 2013 15:26:49 GMT 1
Just got back from thrashing it!
Post by midlifecrisisrd on Mar 6, 2013 16:26:01 GMT 1
Swore I was finished spending on mine. New alloy oil pump cover and a pair of banshee coils from Norbo in the pipeline Oh BU66ER..............I've done it again haven't I Steve
Post by nige on Mar 6, 2013 18:47:48 GMT 1
Replaced forks and put tt600 calipers on her next job bleed the buggers!
Post by flames on Mar 6, 2013 19:00:55 GMT 1
adjusted clutch,dropped needles 1 notch then thrashed the livin daylights out of her.just gotta sort idle to 3k out now.
dal68
Post by dal68 on Mar 6, 2013 19:31:17 GMT 1
took it for mot and it passed
Post by bobbyboy on Mar 6, 2013 19:54:43 GMT 1
Refitted my recently lacquered signed seat cowl today
Post by sidney on Mar 6, 2013 21:17:18 GMT 1
got home from work ,then opend a little package from norbo ;D
