Post by billy on Feb 24, 2013 21:42:29 GMT 1
Tried to remove the seized bleed nipple in my caliper and subsequently snapped it off. Then I drilled it and put a screw extractor in it - which snapped off too. Now I have a very hard and undrillable extractor stuck too!Hahahahaha, classic! How to get it out? Spark erosion is, as far as I know, the last resort now. Look it up.
db8888
Post by db8888 on Feb 24, 2013 21:50:42 GMT 1
Post by raven13 on Feb 24, 2013 21:56:13 GMT 1
started her up. but cant get it to run properly so may have to whip the carb out and check the jets aint clogged up
Post by steve h on Feb 24, 2013 22:11:31 GMT 1
Used some real paint stripper on a pair of red a/c heads ;D
Post by spenerone350 on Feb 24, 2013 22:35:56 GMT 1
PUT THE FRESHLY POWDER COATED FRAME IN THE FRONT ROOM ,HER INDOORS DOESNT SEEM TOO HAPPY ABOUT IT
Wez350
Post by Wez350 on Feb 24, 2013 23:14:22 GMT 1
Open shed door looked thougt F**k it's to cold closed door
Post by Deleted on Feb 24, 2013 23:25:55 GMT 1
Sold one of mine, now hunt for rgv is on
db8888
Post by db8888 on Feb 24, 2013 23:33:07 GMT 1
Open shed door looked thougt F**k it's to cold closed door same aswez350
Post by sidney on Feb 24, 2013 23:48:29 GMT 1
Put gear box back in with all new bearings seals etc , done this on kitchen work top in the warm ;D
Post by Splodge on Feb 25, 2013 1:00:49 GMT 1
higgsy
Post by higgsy on Feb 25, 2013 5:46:58 GMT 1
Ragged it round Brands :-)
Post by Norbo on Feb 25, 2013 11:09:41 GMT 1
Excelent idea i can see this post geting masive. I was showing the Newark 250 to the Virgin bloke this morning and i noticed Cat claw marks on my brand new seat cover so i put a cardboared box broken down over the seat then i added a thick cover over the bike then i replaced the normal double bed cover over that to keep the dust of it . so with any luck no more cat claws scratching it .
Post by mikee on Feb 25, 2013 11:46:16 GMT 1
I think I'd put the cat in the box meself
Post by steeley on Feb 25, 2013 13:05:15 GMT 1
got the wheels built up.got the resleeved barrels on the engine.had a look in the garage ,its to cold so i shut the door .will book a week off in march and get it built up and tested ready for the scorching hot summer ,oh hold on i have just woke up no summer again.
cooler
Post by cooler on Feb 25, 2013 16:10:30 GMT 1
Not the lc but put these cans on the other day ( when it was sunny ) ....im liking them
Post by Norbo on Feb 25, 2013 19:55:06 GMT 1
nice . Now you will be bringing this lovely bike to one of our shows wont you .
Post by andygasgas on Feb 25, 2013 20:19:17 GMT 1
Put 3 heat cycles through new motor checked for leaks polished a few bits and wondered when I might actually get paintwork back and actually ride it
Post by muttsnuts on Feb 25, 2013 20:29:50 GMT 1
Tried to remove the seized bleed nipple in my caliper and subsequently snapped it off. Then I drilled it and put a screw extractor in it - which snapped off too. Now I have a very hard and undrillable extractor stuck too! I gave up and went back into the warm!! Anyone got any ideas how to get it out?? use a centre punch and hit the broken extractor with it, it should shatter it and then remove the pieces using some tweezers or long nosed pliers
Post by Roofmonster on Feb 25, 2013 20:34:58 GMT 1
Thanks Mutts - ill give it a go. Once i get it out I will carefully drill/dremel the nipple and pick the bits out, would be easier to helicoil if I have to than getting the extractor out.
Post by rzsteve on Feb 25, 2013 21:00:15 GMT 1
Stucka bit more yellow pint down on the side panels. Lovely shine on the curves!
Post by copper99 on Feb 25, 2013 21:26:56 GMT 1
Ragged it round Brands :-) You cant say that and NOT add a pic...
Post by copper99 on Feb 25, 2013 21:28:09 GMT 1
Just got back from my mates where we have just done a long overdue complete crank and engine rebuild on my Rd400 special ;D ;D Looks like I have a busy week puting the bike back together now Does the yellow on the barrels stay on for good length of time?...nice work mate
Post by raven13 on Feb 25, 2013 21:31:29 GMT 1
looked at it and wondered why the lc fairies hadnt finished it for me while i was at work
Post by Splodge on Feb 25, 2013 21:41:26 GMT 1
Just got back from my mates where we have just done a long overdue complete crank and engine rebuild on my Rd400 special ;D ;D Looks like I have a busy week puting the bike back together now Does the yellow on the barrels stay on for good length of time?...nice work mate Yes I had them stove enameled sixteen years ago .......Cheers
Post by nige on Feb 25, 2013 22:15:20 GMT 1
Changed the fork seals
Post by speedysquires on Feb 26, 2013 0:09:06 GMT 1
Stripped the carbs today
crip
Post by crip on Feb 26, 2013 9:36:20 GMT 1
got fork seals and new tyres to fit ready for spring, but i'm holding out as the weather is soooo shit...boooooo
Post by flames on Feb 26, 2013 11:19:31 GMT 1
Not the lc but put these cans on the other day ( when it was sunny ) ....im liking them look at that back tyre.......i do love to see evidence that a bike has been ridden PROPERLY. well done dude,i am suitably impressed. ;D
Post by flames on Feb 26, 2013 13:47:30 GMT 1
drained fuel tank,sat a crank with a slightly notchy bearing in the premix.bearing now running free.removed carbs and reeds to fit 6mm spacers.swapped home made air filter for a proper one.had 6 attempts at stopping fuel leak from rear screw on fuel tank.no success at that so gave up n came inside for coffee before i loose my rag and stove said tank in with a sledge hammer.
cooler
Post by cooler on Feb 26, 2013 15:14:37 GMT 1
nice . Now you will be bringing this lovely bike to one of our shows wont you . would love to norbo but she's not really up to show standard and looking at some of the beauties on your stands she would let the side down a little... Flames.....thats what i said to the bloke i bought them of ..
