Post by tipfinchy on Apr 7, 2021 18:27:19 GMT 1
took the ypvs rad plates off but it does make the oversize rad look a bit big now tho , trimmed the belly pan underneath to give the exhausts a bit more room , kicked hell out the kicker again before realising the switch was in off position (not for the first time ) warmed it up and changed the gearbox oil , took the exhausts off to get them stoved at a local coater ,and give it a bit of a clean mart
Post by fletche36 on Apr 7, 2021 20:03:24 GMT 1
Picked up 5 litres of Exol Optima ยฃ20 ๐ค best value quality oil ever !
Post by Tobyjugs on Apr 7, 2021 20:21:53 GMT 1
took the ypvs rad plates off but it does make the oversize rad look a bit big now tho , trimmed the belly pan underneath to give the exhausts a bit more room , kicked hell out the kicker again before realising the switch was in off position (not for the first time ) warmed it up and changed the gearbox oil , took the exhausts off to get them stoved at a local coater ,and give it a bit of a clean mart That is a coincidence i was just looking at this picture thinking the same thing and thinking about posting the question does this rad look too thick?
Post by tipfinchy on Apr 7, 2021 21:02:33 GMT 1
took the ypvs rad plates off but it does make the oversize rad look a bit big now tho , trimmed the belly pan underneath to give the exhausts a bit more room , kicked hell out the kicker again before realising the switch was in off position (not for the first time ) warmed it up and changed the gearbox oil , took the exhausts off to get them stoved at a local coater ,and give it a bit of a clean mart That is a coincidence i was just looking at this picture thinking the same thing and thinking about posting the question does this rad look too thick? mine is black and it looks HUGE ,but i am sure it wont bother me to much or i will find something different to break up the size of it ,,,,,,,,,,, if you want to try some ypvs rad plates mart
Post by Tobyjugs on Apr 7, 2021 21:14:15 GMT 1
That is a coincidence i was just looking at this picture thinking the same thing and thinking about posting the question does this rad look too thick? mine is black and it looks HUGE ,but i am sure it wont bother me to much or i will find something different to break up the size of it ,,,,,,,,,,, if you want to try some ypvs rad plates mart Ive been thinking about installing the MK 1 radiator from the Bakker bike, its thinner and curved.
Post by Tobyjugs on Apr 9, 2021 11:31:57 GMT 1
I blew a fork seal last week so thought it was time to service the suspension. As the rear shock is now beginning to feel a bit bouncy it has been sent off for a service as well.
Post by wallcraft on Apr 9, 2021 20:15:55 GMT 1
mine is black and it looks HUGE ,but i am sure it wont bother me to much or i will find something different to break up the size of it ,,,,,,,,,,, if you want to try some ypvs rad plates mart Ive been thinking about installing the MK 1 radiator from the Bakker bike, its thinner and curved. nahh leave as, nice and butch like the front and back ends, this is one of my favourite Looking LC's on here๐
Post by midlifecrisisrd on Apr 10, 2021 12:33:58 GMT 1
Ordered a Gen crank, primary gear and clutch basket ๐ณ๐ค๐ญ
Post by elsiefan on Apr 10, 2021 13:42:29 GMT 1
Looks like my oil leak may be coming from the oil pump oil seal ๐ญ Clutch cover is off and waiting for the parts to arrive so I can fix her up and get riding again. Thankfully the weather has turned grey and chilly, so I am in no mood for a ride atm.
tlmark
Post by tlmark on Apr 10, 2021 15:34:19 GMT 1
After finding my rear wheel spacer had some rust starting to come through
I got some stainless steel replacements
Post by yamman1066 on Apr 10, 2021 15:51:32 GMT 1
i fit a locking plates on your nuts there
Post by markrd250lc on Apr 10, 2021 15:51:36 GMT 1
Just started the twin disc conversion on the 250LC, stripped both callipers and discs and painted with PJ1 satin black, drying in the conservatory, hope to start to reassemble tomorrow.
tlmark
Post by tlmark on Apr 10, 2021 16:42:44 GMT 1
i fit a locking plates on your nuts there Itโs all good๐, they are thread locked on as are the disc bolts I prefer the look with out the locking tabs
Post by stusco on Apr 10, 2021 16:49:58 GMT 1
i fit a locking plates on your nuts there Itโs all good๐, they are thread locked on as are the disc bolts I prefer the look with out the locking tabs There needs to be a full nut(really should be at least flush ideally one thread through the nut) use nyloc or metalock nuts
Post by 3tj6 on Apr 10, 2021 17:45:30 GMT 1
Took replacement power valves up to dave muttsnutts ๐
Post by 29davyt on Apr 10, 2021 18:14:55 GMT 1
Fitted a couple of new Spark plugs
Post by elsiefan on Apr 10, 2021 18:25:41 GMT 1
Looks like my oil leak may be coming from the oil pump oil seal ๐ญ Clutch cover is off and waiting for the parts to arrive so I can fix her up and get riding again. Thankfully the weather has turned grey and chilly, so I am in no mood for a ride atm. Also spoke with Arrow about my oil pump and he gave me loads of good advice, from his years of experience, cheers Sir ๐
Post by stusco on Apr 10, 2021 18:28:01 GMT 1
I fitted four new plugs to my gamma no easy task
Post by dougw on Apr 11, 2021 18:36:47 GMT 1
Took the ypvs codnor microns off the 4L0 350 and fitted the 31K YPVS standard pipes, after cutting the mounting brackets off and re welding them back in position to suit the 4L0 .
Mid range flat spot gone.
Post by dougw on Apr 14, 2021 18:53:49 GMT 1
Checked timing on the 4L0.
I left it in the position it was in when I got it after the full rebuild.
It was set at 0.7mm BTDC. Oops.
As running standard bore and compression, set it to 2mm.
Checked it with strobe, marks aligned.
I now have midrange !
Post by tacky1 on Apr 15, 2021 7:48:58 GMT 1
Post by hudtm60 on Apr 15, 2021 17:14:39 GMT 1
Thanked myself for labeling the overflow pipe ends. When I set the petc**k to prime, bike became incontinent, but I was able to tell which carb had a float stuck and tapped it with a socket extension. Flow stopped.
Post by deano4lo on Apr 15, 2021 19:15:32 GMT 1
Tyres off, bearings out of wheels, already for cj wards in morning...
Post by donkeychomp on Apr 15, 2021 21:35:01 GMT 1
It's always sad to see them go. Bike looks amazing. Alex
Post by JonW on Apr 16, 2021 1:09:37 GMT 1
Thanked myself for labeling the overflow pipe ends. When I set the petc**k to prime, bike became incontinent, but I was able to tell which carb had a float stuck and tapped it with a socket extension. Flow stopped. What a great idea, I hadnt thought of that but will do that with mine too.
Post by hudtm60 on Apr 17, 2021 1:00:25 GMT 1
Sonโs VW is in the garage...heโs borrowing my four wheeler to get to his work so Iโve been biking to my job. Luckily weather is cooperating. As much as I really, really love the 500, when I get on this, everything feels like itโs in the right place, you can throw it into any corner and hitting the power band is still a buzz.
Post by andy748 on Apr 18, 2021 20:24:19 GMT 1
Post by steeley on Apr 18, 2021 20:30:28 GMT 1
I will be in my new lock up Monday checking over the lc and Tzr ready for mot next week .
Post by elsiefan on Apr 20, 2021 0:14:39 GMT 1
After replacing all the gaskets and oil seals in the clutch cover, plus replacing a couple of slightly iffy looking parts and resetting my oil pump, I put 1.5L of Motul transoil in the gearbox and cross my fingers that I've fixed the oil leak.
Post by dougw on Apr 20, 2021 11:01:39 GMT 1
Took the 350LC barrels to Trick Tuning to have the wonky transfers sorted out.
