Post by Tobyjugs on Jan 14, 2021 12:26:15 GMT 1
I exchanged The TSA's for a set of standard cigar pipes on my 400cc engine. Since ive rejetted the carbs to suit, i wanted to get it checked on the dyno for the jetting and also for the diameter of the stinger.
I'm now back in the the GS 550 club.
It made 57 PK.
I wanted to put the cigar pipes on my 250 and test the heat proof powder coating on the pipes But the bike is too modified for plug and play.
So far the powder coating is working well and there is also lots of salt on the roads at the moment.
Post by mangocrazy on Jan 14, 2021 22:38:46 GMT 1
 Shortly before the snow arrived in Sheffield, so did these little beauties, fresh from powder-coating and refinishing by the most excellent C J Ward of Burton on Trent. They are probably better than new now...
Post by ERic350 on Jan 15, 2021 16:40:27 GMT 1
Airbox mounted including rubbers in a shed at 0 degrees Celsius. A job for which you need tiny hands. Which I have not. At some time thought my cold fingers would brake into pieces. But, job done. Let's see if it will run tomorrow
Post by st66 on Jan 15, 2021 22:21:19 GMT 1
Nutted the exhaust, can just for the crack lol 🤣🤣👍
Post by andy748 on Jan 16, 2021 19:16:12 GMT 1
Pulled the engine from me N1 hybrid, it's always had a clutch rattle from the last rebuild, it's done around 2500 miles since i dropped a new crank and pistons in it, quite pleasantly surprised how the internals look, bit of carbon build up, but it's getting re-bored this time so no worries there. Going to change the gearbox bearings as it's the main clutch bearing that's knackered.The detonation marks on the head have always been there. Andy. IMG_4065 by Andrew Jolly, on Flickr IMG_4066 by Andrew Jolly, on Flickr IMG_4067 by Andrew Jolly, on Flickr IMG_4068 by Andrew Jolly, on Flickr
Post by marrcel on Jan 16, 2021 19:31:00 GMT 1
Post by Tobyjugs on Jan 17, 2021 11:13:34 GMT 1
Fitted an eight plate clutch last night. Looking forward to testing it.
Post by smp1111 on Jan 17, 2021 13:05:01 GMT 1
I am doing a full restoration and restoration of my lc2. I bought it in very poor condition because there were no other options on sale in Russia. Now I'm looking for spare parts)
Post by stevel1305 on Jan 17, 2021 20:42:40 GMT 1
Took the battery off, put it on the Optimate for an hour. Reconnected it and five kicks later it lives! I’m so looking forward to Spring - but some time to go yet!!
Post by 29davyt on Jan 17, 2021 21:17:52 GMT 1
Post by deltadave on Jan 17, 2021 21:35:12 GMT 1
Started to rebuild clocks as the trip on the mph broke ,so using xs750 internals and 3D printed backs to make good flic.kr/p/2kt8qBq
Post by hudtm60 on Jan 20, 2021 5:52:41 GMT 1
Carbs peeing fuel?  I’m going in!
Post by jonw on Jan 20, 2021 7:02:13 GMT 1
Ohh Chris! lovely to see that clean bike coming apart.
FWIW if you fit the TZR fuel tap instead of the OEM twin outlets to the tank, you can remove the tank totally if you wanted to do that.
Post by marrcel on Jan 20, 2021 17:47:03 GMT 1
Closed case of spare engine. New crank and seals.
Post by gunny on Jan 20, 2021 19:22:18 GMT 1
Post by gunny on Jan 20, 2021 19:23:18 GMT 1
And these turned up
Post by copper99 on Jan 20, 2021 20:18:50 GMT 1
Carbs peeing fuel?  Situation normal.... despite changing all the internals and having them bench flow tested many times, they still do it on random occasions, however, riding (thrashing ..) it settles it all .
richb
Post by richb on Jan 21, 2021 11:50:50 GMT 1
My 500 does exactly the same after it has been stood for a while but stops after some fresh fuel has run through the carbs and cleared out the crap that seems to accumulate when fuel is left for a while
Post by midlifecrisisrd on Jan 21, 2021 14:23:14 GMT 1
Clutch in. Barrels and head on.Painted some disc centres    DAD!!! Why does dinner taste of paint? 🤣🤣🤣 Steve
Post by trappena on Jan 21, 2021 19:49:40 GMT 1
My 500 does exactly the same after it has been stood for a while but stops after some fresh fuel has run through the carbs and cleared out the crap that seems to accumulate when fuel is left for a while +1
Post by oldbritguy on Jan 24, 2021 9:06:39 GMT 1
Unwrapped some engine parts just returned from Ron at Fahron  These are for the "spare" engine which will hopefully make an appearance soon John
Post by Tobyjugs on Jan 24, 2021 9:16:13 GMT 1
Unwrapped some engine parts just returned from Ron at Fahron  These are for the "spare" engine which will hopefully make an appearance soon John Nice chunky liners
Post by headcoats on Jan 24, 2021 13:49:00 GMT 1
Moved them out garage to get new settee in Put them back !
thomas
Post by thomas on Jan 24, 2021 17:34:57 GMT 1
Sorting through some spares
Post by geoffb on Jan 24, 2021 17:49:15 GMT 1
Fitted new RamAir foam filters! As some of you will know, removing the old air box is a B@stard but fitting the new foam filters took <10 minutes. 😎 Now for some re-jetting. 🤓 Yamaha RD350LC RamAir by Geoffrey Butler, on Flickr
Post by liffy16 on Jan 24, 2021 20:59:38 GMT 1
Fitted grab rail to my rd250lc put original headlights lens into pattern headlight bowl/rim ,got to fit plastic disc cover/blanking to front wheel
Post by Tobyjugs on Jan 24, 2021 21:02:55 GMT 1
Fitted grab rail to my rd250lc put original headlights lens into pattern headlight bowl/rim ,got to fit plastic disc cover/blanking to front wheel How does the pattern rim fit? good or bad?
Post by liffy16 on Jan 24, 2021 22:11:12 GMT 1
Fitted grab rail to my rd250lc put original headlights lens into pattern headlight bowl/rim ,got to fit plastic disc cover/blanking to front wheel How does the pattern rim fit? good or bad? Yea fits ok ,payed £25 for the lens and rim,rim was bashed up but I only wanted the lens anyway, so visually it looks original ,straight swap 👍
Post by gunny on Jan 26, 2021 23:26:21 GMT 1
Popped to the powder coaters  And the worst job of an Lc resto
Post by jonw on Jan 27, 2021 12:10:07 GMT 1
6mm line tape... makes LC wheels soooo much easier.
