robw
Post by robw on Feb 5, 2013 19:47:00 GMT 1
I am aware that the Haynes book of lies shows the seals incorrectly fitted. Could someone tell which way it should be? Is it as a normal seal will be with the face on the outside as you look in ? Cheers Rob
Post by Yogi on Feb 5, 2013 20:08:30 GMT 1
Castle side facing out wards from crank mate,looks like its inside out
Post by Yogi on Feb 5, 2013 20:14:45 GMT 1
Unless mine were in back to front.
Post by Tone on Feb 5, 2013 20:44:37 GMT 1
Post by Yogi on Feb 5, 2013 21:01:03 GMT 1
Mine were in backwards then,lucky it's not rebuilt yet,result
robw
Post by robw on Feb 5, 2013 21:16:13 GMT 1
Cheers for that, the RZ website is very good. So I will using that to help me build the engine in a couple of weeks, once I get my crank from Norbo.
Rob
Post by Yogi on Feb 5, 2013 21:23:35 GMT 1
Waiting 4 my crank off Norbo. 2',I'm well glad you asked that question,would prob have put seals in wrong as I took pics to rebuild with
Post by nikfubar on Feb 5, 2013 21:35:52 GMT 1
I'm well glad you asked that question,would prob have put seals in wrong as I took pics to rebuild with You wouldn't be the first ;D
Post by Denzil on Feb 5, 2013 21:55:01 GMT 1
Hi, the "Scooter Help" web page is fantastic, i used this to build my engine up and it is very imformative and as helped me loads, the only issue i had was on the clutch rebuild bit they said I needed 2 rubber clutch rings total, this is incorrect as Norbo pointed out to me, I actually needed 1 between each clutch plate. Apart from that I would recommend any body buiding an engine to use this as farrrrrr! better then Paynes manual.
Post by markhoopy on Feb 6, 2013 0:22:31 GMT 1
I bought a crank from Norbo a couple of weeks ago, fitted new seals and was just about to put the top crankcase on when I noticed the Haynes manual showed the 'castle' side of the seal facing out, which was the opposite to what I had done. I swapped it round, built the bottom end, then posted some pics of my rebuild. Mixed emotions when my mistake was pointed out .. pulling the cases apart, cleaning off bearing lock, swapping the seal round yet again, but at least all this was before I had rebuilt the top end, or even worse put the engine back in the frame ..
I should burn the Haynes book, I really should.
Post by Yogi on Feb 8, 2013 18:09:35 GMT 1
Probably wont be the last either
Post by Denzil on Feb 9, 2013 9:12:13 GMT 1
Castle bits should face the bearing I.e inside. The Haynes is wrong, the seal won't be able to seal if the castle bits are on the outside.
Post by Tone on Feb 9, 2013 10:43:14 GMT 1
A while after I got my LC2 I stripped the engine to have the crank rebuilt and noticed the RH seal had been fitted wrong with the castle bits facing out. It didn't seem to affect the running and didn't burn any gearbox oil either. Probably a common error as it even shows the seal the wrong way around in the parts catalogue from the very first LC upto the 1985 F1 powervalve but the 1986 F2 and onwards it shows it the correct way.
Tone
Post by nikfubar on Feb 9, 2013 11:39:37 GMT 1
I'm sure someone will correct me if I'm wrong but I was led to believe that the seal would work whichever way it was fitted but the reason the castleations were against the bearing was to aid the flow of petrol/oil mixture around the bearing ensuring adequate lubrication but why the seals different on the other end of the crank I'm not sure as this is the one which usually packs up first.
Post by Deleted on Feb 10, 2013 1:56:39 GMT 1
that makes sense to me nik
Post by Denzil on Feb 10, 2013 10:16:11 GMT 1
+1
Post by Tone on Feb 10, 2013 16:38:50 GMT 1
Seem to remember reading somewhere that the LH bearing usually goes first because of the weight of the rotor on the end of the crank.
Post by garry1366 on Feb 11, 2013 22:20:46 GMT 1
I've been looking for an engine rebuild guide just like the one on scooterhelp for the LC, does anyone know where I can find one?
Cheers
