Post by deltadave on Jun 26, 2014 23:44:36 GMT 1
starting to come together now
Post by dave1963 on Jul 8, 2014 19:30:19 GMT 1
very nice soon be done
Post by deltadave on Jul 14, 2014 21:21:06 GMT 1
Post by deltadave on Sept 24, 2014 10:17:16 GMT 1
after close inspection found carbs to be a mile out needle on top notch , #110 main jet # 15 idle jet . so with a little help from you guys purchased some carb kits from www.nrp-carbs.com/shop 01618328646 . carbs ultra sonic cleaned (thanks to boss loaning a sonic cleaner for a couple of week ;-) ) carb kit carb's complete cleaned with kit Seat before and after recovering crank cases stripped ready for vapour blasting
Post by ellasae on Sept 24, 2014 16:12:13 GMT 1
It's good to see another old girl coming back to her former glory
I'll be doing the same to mine (hopefully) this winter
Post by deltadave on Sept 29, 2014 22:34:12 GMT 1
found this piccy of the 250 i had when i was 18 ,hard to believe almost 25 years ago and here i am building another one wish i hadnt sold it for £600 back then ,would have saved a fortune
Post by farmboy on Oct 2, 2014 19:51:48 GMT 1
Got to love back in the day pics.
Whats wit the seat cowl ? Looks like a standard seat cushion at the front.
Post by Bertie Wooster on Oct 14, 2014 18:03:21 GMT 1
Defo a nice colour scheme
Post by deltadave on Oct 15, 2014 22:10:07 GMT 1
Carn't remember what make the seat cover was but can remember it cliped over the original seat and was made from fibre glass ,possible a ARD item ,but this was back in 1989
Post by arrow on Oct 15, 2014 22:55:58 GMT 1
Nice work. Wow, those engine cases certainly need to be cleaned up!
Post by crash on Oct 16, 2014 12:14:02 GMT 1
Nice! You a hizzy fan Dave?
Post by deltadave on Oct 20, 2014 12:52:24 GMT 1
yep he was a star just didnt seem to get the big break ,couldnt resist the helmet ,but had to be drunk at the tt a few year ago to buy it ,damm beer tent lol
Post by deltadave on Nov 23, 2014 21:44:55 GMT 1
last bits of zinc coating ,had to be last bit that got required finish without a polish !!!!!
Post by bofski25 on Dec 17, 2014 21:17:26 GMT 1
who covered the seat looks good
Post by turk on Dec 21, 2014 23:14:22 GMT 1
Looking good Keep us up to date.
Post by deltadave on Jan 30, 2015 19:48:01 GMT 1
Post by seang14 on Jan 31, 2015 19:32:16 GMT 1
Hi Dave, Wher'd you get the Kit for doin The Zinc Coating mate, and Is it expensive to do?? You look to be doing a great job of it!!
Cheers Sean G
Post by 4l04ever on Jan 31, 2015 23:17:31 GMT 1
Careful with the keyster kits, as they jets/needles are meant to not be very accurate copies.
Post by deltadave on Feb 3, 2015 21:30:41 GMT 1
Hi Sean i purchased the kit a couple of years ago approx £140.00 and purchased a variable meter from them afterwards found this to be easier to set amp/volts on from these people gaterosplating.co.uk/Zinc-Plating-kit .Lets say my first few attempts were not great but practised for a while and hopefully getting better at it .
Post by deltadave on Feb 3, 2015 21:34:14 GMT 1
Cheers 4L04ever will keep my eye on them when ready to set up ,i sill have my original needles it was all the jets that were wrong in a second hand fleebay purchase :-(
Post by deltadave on Feb 24, 2015 20:58:45 GMT 1
Gutted started to strip old engine to find one barrel on standard bore and other on 0.25 oversize ,now time for a piston kit and rebore ,why do people not do a proper job in the first place aaaahhhhh !!!!!!
Post by skydemon on Feb 25, 2015 16:05:50 GMT 1
Wouldn't worry. The only decent thing on mine was the barrel and Pistons. The rest finiteness f@cked LOL
Post by deltadave on Mar 23, 2015 23:05:13 GMT 1
Post by stumpy on Mar 24, 2015 17:11:21 GMT 1
Just built my bottom end up, lovely doing it with all clean and vapour blasted cases
Post by Delbert on Mar 28, 2015 9:09:06 GMT 1
Coming on nicely mate ,, your doing well time wise , I took nearly 7 years !!!
Post by deltadave on Mar 30, 2015 20:33:21 GMT 1
just replaced the torsion spring on gear shaft thats from a powervalve now in great condition no grove on shaft ,so after mod and a £13 gear shaft from ebay hope no oil leak when built . had to grind head from pin to remove the roker arm etc from shaft to replace torsion spring then ask a nice friend just to weld over the head area to form a solid fix.Sure there was an easier way but couldnt see it
Post by deltadave on Apr 5, 2015 22:20:50 GMT 1
gearbox and crank in ready to crack on
Post by deltadave on Apr 10, 2015 19:53:38 GMT 1
here's the problem i found explains the movement in the clutch before i put together ,will post strip and build up to help everyone with the build
Post by carioca656 on Apr 10, 2015 21:12:43 GMT 1
just looked at pic of carbs are they a mismatched pair?
adie
Post by deltadave on Apr 10, 2015 21:34:27 GMT 1
Hi adie not 100 % sure will check tomorrow all jetted and needled up the same bought from ebay a while ago amd had to do jetting etc a mile out
