Post by arrow on Jun 13, 2012 19:24:59 GMT 1
Hi i thought some people would like to see this its the official Yamaha oil pump tool with all the shims which are stored in the dome at the end of the gauges Cool, didn't know one existed.
Post by arrow on Jun 13, 2012 19:32:27 GMT 1
Now there's a thought. Based on the figures I quoted for the 250e this would give around 27:1 at idle revs and around 32:1 at full bore. The idea was because of the larger capacity and power increase in mine I wanted some more oil but if I increase the pump setting it is very smokey at low revs, It was also so the premix would stop the very precious tanks from rotting. Very easy to change back and forth also. Steve Another good option here, already discust on a previous thread, is to use the standard pump setup and additional premix at around 140:1~150:1 This would spread the low/high speed ratio's out quite a bit more to around 52:1 and 17:1 (thats using the 150 mix)
Post by skaterboy on Jun 14, 2012 10:27:47 GMT 1
Ohhhhhhhh that looks like a nice bit of kit , were did you get it . ;-)
db8888
Post by db8888 on Jun 14, 2012 12:32:36 GMT 1
Hi the original part number is 90890-03079 this has changed to 90890-03180 this is still availble in Belgium
£26.88 +vat i have been told that because the number has changed should not make any big changes to the part
Cheers Dave
Post by barbarossa on Jun 14, 2012 19:47:34 GMT 1
Having given due consideration to al the various replies, I think leaving the pump in situ but without the operating cable AND running pre-mix at 40:1 is the way to go. That way oil gets to the vital bits at tickover, full-bore and on the over-run.
Post by reggieperrin on Jun 15, 2012 9:13:05 GMT 1
Arrow,
YPVS question, On my N1, I just stripped the oil pump out for the rebuild and noticed that the washer on the end of the drive shaft for the oil pump is missing. This washer is indicated in the manual and I presume is purely a thrust washer, although not under much load seeing as it's only a plain washer. part number is 90201-08624 Do the pumps differ from model to model with this washer..?
Cheers Reg
Post by arrow on Jun 15, 2012 9:40:17 GMT 1
Arrow, YPVS question, On my N1, I just stripped the oil pump out for the rebuild and noticed that the washer on the end of the drive shaft for the oil pump is missing. This washer is indicated in the manual and I presume is purely a thrust washer, although not under much load seeing as it's only a plain washer. part number is 90201-08624 Do the pumps differ from model to model with this washer..? Cheers Reg Hi Reg, this is a common part for all models, as far as I know. As you say its not a hard working part and I know of people who run without it with no problems.
Post by reggieperrin on Jun 15, 2012 10:29:55 GMT 1
Cheers, I've checked the pump and there's no significant wear so it doesn't seem to have done any damage... I've ordered one anyway and will check the end float before fitting it...
Reg
