Post by raven13 on May 28, 2012 15:21:49 GMT 1
i've been working thru the electrics on the mk3 125lc and i have one connector that i have nothing to plug into. its on the loom next to the connector for the stator. lrg white with 5 spade conections inside. is there supposed to be a second set of wires coming from the stator??
Post by mellow on May 28, 2012 16:59:11 GMT 1
yep theres white/red & white/green from pickup and............hang on..just check manual ;D
Post by mellow on May 28, 2012 17:03:04 GMT 1
theres a red/black female bullet connector a yellow female bullet a 3 pin connector with light blue/brown & black wires and a 3 pin connector with 3 white wires tell me the colour of wires n il tell u wot it goes to
Post by mellow on May 28, 2012 17:04:25 GMT 1
only ones i can see with 5 are the cdi and ypvs wires. if u aint got ypvs u wont need it
Post by raven13 on May 28, 2012 17:42:54 GMT 1
ok little mistake. ive got 2 lots of wires coming fron the stator. the connector block goes into the loom along side 2 other wires (coloured white with red stripe and white with green stripe) and have the following colours. black. black with yellow stripe. white with black stripe. white with red stripe. yellow with green stripe.
Post by mellow on May 28, 2012 23:14:33 GMT 1
ypvs control unit and servo for those
Post by raven13 on May 28, 2012 23:24:32 GMT 1
cheers mell. wish the indicators were as easy to solve. had to open up the loom and replace a lenth of wire running both ways from the relay. turned to dust, must have had some water ingress via the terminals. but its sorted now. just need to solder some new connectors on and thats the lights finished.
Post by mellow on May 28, 2012 23:29:11 GMT 1
glad i could help
