nickc
Post by nickc on Jun 18, 2010 23:33:09 GMT 1
Looks great so far, just wish i had the skill to do something like that.
Post by nikfubar on Jun 24, 2010 10:06:25 GMT 1
Picked up the finished pipes and O ringed head from Slinger last night motorcycle porn ;D
Post by billy on Jun 26, 2010 5:46:48 GMT 1
Waaaa!! Best looking pipes ever! Really REALLY nice, hope they work as good as they look too.
Post by nikfubar on Aug 15, 2010 22:52:31 GMT 1
Post by nikfubar on Oct 3, 2010 17:48:56 GMT 1
Now that the X factor / Strictly dancing and other such garbage is back on I don't get a look in on the Tv so spent a bit more time in the garage ;D I've made the mounts and fitted a Cagiva Mito 125 rad as it holds 50% more coolant than the F2 rad, that should keep the bugger cool also fitted a RGV thermostat which opens at 50 degrees C. Also fabricated a Renntec style radiator grill, should look OK when it's powder coated satin black Finally got the R1 speedo sensor and loom so I can test out my R1 clocks, fabricated a mounting bracket you can see in the photo above, spun it up with a valve grinding tool connected to a drill and it worked first time shows 38MPH with the sprocket spinning at about 3000 rpm not sure what that will be in the real world but hopefully a speed healer will sort it out.
Post by scott on Oct 3, 2010 18:22:20 GMT 1
thats lookin well nice nik,love the rad and rad gaurd
Post by andygraham on Dec 4, 2010 23:20:17 GMT 1
wow what vision. i can only see one step in front! you must be looking 4 or 5 my brain would fry trying to work it all out fantastic job keep it up
Post by Dieseldog on Dec 6, 2010 15:14:32 GMT 1
Looking really good, thought I was doing a good job with my NC30 hybrid till I saw this My hub rear hub is due back 2moro from Rick Oliver - mod to take 17inch wheel from VFR750. Was told you fitted RGV switch gear to one of your hybrids, any pitfalls with going down that route? Cheers Nigel
Post by nikfubar on Dec 7, 2010 1:17:36 GMT 1
Thanks for comments guys ;D Fitted RGV switchgear to my last build, work great I just cut the plugs of the old RD switches and connected them to the RGV ones, I think I had to re-wire the kill switch as the RGV one works the opposite way but just a matter of moving one wire to the opposite terminal in the kill switch.
Post by LC'Adam on Dec 7, 2010 1:22:33 GMT 1
This is gunna be sorted bike nik, I'm a fan of your builds You decided on a paint scheme yet? Adam
Post by nikfubar on Dec 7, 2010 1:40:22 GMT 1
This is gunna be sorted bike nik, I'm a fan of your builds You decided on a paint scheme yet? Adam Cheers M8 ;D Was thinking of black with blue speed blocks & the wheels, dark blue in the centre fading out to silver on the rims. But I'm always open to suggestions if anyones got any ideas ;D
Post by nikfubar on Dec 25, 2010 3:09:06 GMT 1
Been having fun wiring had to completely rebuild the loom cos I moved all the electronics boxes and fitted the wiring for the R1 speedo & a speed healer. Finally found a good straight NC35 front wheel & bought a set of Kagzumi wavey discs. Got my mate to make me up a new front wheel spindle to fit the new wheel to the GSXR forks, well happy only cost me a pint ;D Also bought a carbon fibre front mudguard, now the front end is complete, well happy Right thats it the mock up's complete, time to strip it all down and send off the frame wheels etc for powder coating.
Post by seanrd on Dec 25, 2010 3:53:04 GMT 1
Looking bloody good now Can't wait to see it all done. Well done on the wiring aswell, can't wait to do my loom NOT
Post by Norbo on Dec 25, 2010 8:13:52 GMT 1
f**king love that front end .
Post by billy on Dec 26, 2010 0:43:14 GMT 1
I think I've said it before but I'll say it again - man this bike will be awesome! Nice to see another front end then RGV for once, (not that it's anything wrong with RGV lol, just so damn common) love those radial calipers too.
jay20t
Post by jay20t on Jan 7, 2011 15:16:03 GMT 1
Great looking project Can i ask where you got the clutch slave cyclinder from?? thanks Jay
Post by nikfubar on Jan 7, 2011 15:55:01 GMT 1
Post by nikfubar on Apr 30, 2011 0:19:39 GMT 1
And we continue ;D Powder coatings done prepped loads of bits & can finally start the build proper when I get my barrells back from Mick Abbey. Gonna fit the barrels & head after the engines in as it's a bit tight & I don't want to scratch the frame. Polished the k4 bottom yoke
Post by rigga on Apr 30, 2011 9:03:43 GMT 1
Love these build threads,some guys have waayyyy too much talent and vision,going to be stunning when its finished .
Post by morton01 on May 1, 2011 22:55:21 GMT 1
'kin awesome work mate. Like the frame, forks .....everything..... particularly the calendar in the background
Cheers
Post by nikfubar on Jun 1, 2011 22:21:11 GMT 1
Got some more done ;D made a clutch window & refurbished the casing with new seals & bearings, fitted one of Norbo's hi flow impellars, serviced the pump & fitted a shiney new ali dip stick. Barrels come back from Mick Abbey who did a fast road tune & honed the bores, fitted new PV bearings & seals. Now we're getting anal I nickel plated all the engine studs to stop them going rusty. Finally got the lump back together with new crank, clutch, springs, seals. Fitted the hydraulic clutch, nickel plated the engine mount plates & used stainless bolt set from NK racing. Ground the top of the crank case to match the transfer ports & trimmed the base gaskets to match. Ready now to fit the new pistons & finish the top end. ;D
Post by nikfubar on Jul 9, 2011 22:32:19 GMT 1
Done a bit more made some special tools so I could strip down the GSXR forks, now there all rebuilt with new seals, oil etc ;D Got the front end all fitted & got some smart new shorty billet levers for the radial brake master & clutch master cylinders. ;D Got the top end back together, just waiting for Norbo to get some more stainless head bolts in, then I can finish it & plumb in the cooling system & rad. Fitted the rear sub-frame, battery & RS250 oil tank. Stainless steel under tray, shiney shiney ;D ;D
Post by Norbo on Jul 13, 2011 10:42:58 GMT 1
I love looking at the calender change as you look threw the posts ,.
Post by mellow on Jul 13, 2011 15:56:36 GMT 1
nice ohlins damper mr fubar u out on it this weekend then
Post by nikfubar on Aug 6, 2011 1:44:18 GMT 1
Got the final bits for the hydraulic clutch & f**k me if it don't work perfect first time. ;D Here's this months cheeky little offering ;D
Post by JonW on Aug 9, 2011 0:46:35 GMT 1
wonderful work Nik, as always!
lcolin
Post by lcolin on Aug 9, 2011 20:26:13 GMT 1
i love the fact that the calender is now getting as much of a following as the very sexy looking bike. Look forward to seeing the finished bike (and next months calender picture!!)
Post by nikfubar on Aug 12, 2011 17:59:53 GMT 1
Just got me powder coating back from Aerocoat & all I can say is WOW ;D pictures don't do it justice. Wheels were £100.00 each & the swinger, side casing & headlight brackets were £60.00 Definately be using them again
Post by midlifecrisisrd on Aug 12, 2011 21:44:29 GMT 1
Nick, the aerocoat looks amazing.
Makes me want to take off my polished nana arm and get it done to save me polishing the bass constantly
Bike looks superb.
Post by billy on Aug 13, 2011 21:14:45 GMT 1
Holy crap, is that actually powdercoat on the swinger?? It looks like it's polished aluminum. Very nice I must say. I'm not getting anything polished again, pain in the arse You're goddamn right about that sir! I'm also sick of it. It's nice when it's freshly polished but keeping it shiny is a P.I.T.A. Not to mention polishing a big part from scratch. I couldn't be arsed to polish the footrest hangers on the 125, (and they're not even big) I'll do that "some other day" lol. ;D
