Post by christyres on Oct 1, 2011 20:08:16 GMT 1
MY MATES TSS LC HYBRID.HES AIMING FOR 100 BHP + Attachments:
Post by christyres on Oct 1, 2011 20:10:21 GMT 1
PIC2 Attachments:
Post by JonW on Oct 3, 2011 22:59:33 GMT 1
That will be a brute! Wonder how those small silencers will sound... earplugs all round I reckon!
lcolin
Post by lcolin on Oct 4, 2011 6:45:22 GMT 1
Holy sh*t. Thats gorgeous. Tell us more - lots more.
A full spec and more piccys would be good.
Post by lcowner on Oct 4, 2011 6:45:26 GMT 1
awsome i bet it cost a pretty packet with all them trickbits
r1olly
Post by r1olly on Oct 4, 2011 8:41:08 GMT 1
awesome!
Post by smads on Oct 4, 2011 9:00:03 GMT 1
tss 500 barrel tss 500 domes tss 500 pv tss 500 4mm 115 rod tungston balanced crank tss 500 oil pump gear tss 500 73mm ultra light flat top teflon coated pistons tss 500 cnc ported and decked casings...new tss 500 modified stator and flywheel tss 500 ignition by ignetec with full pv control tss 500 uprated gearbox hinson billet clutch basket lockup kit clutch pancake bearing staight cut gears shift pro v force reeds 38mm pwk carbs remote thermostat aluminium rad 10mm thicker mark dent performance fabrication pipes rgv twin coils
gsxr 400 front and rear wheels,bigger sprocket carrier sp rgv forks...polished hyabusa six pot brakes...front r1 caliper...rear...nk brake stay arm nk rear sets aprilia mille swinging arm...cabon covers frame seam welded...although suspect after a year may brace it...lol goodridge brake lines rdlc crazy master cylinder pot rethal drag bars
bowt it rearly unless i forgot summit...
and seam on pipe is bit annoying but now its all polished it sort of blends in...but yeah...
Post by smads on Oct 4, 2011 9:03:10 GMT 1
ohhh and cost is just over 12 grand....ouch!
ohhh sound should be same as chris tyres bike...his hit 120 decibel on test he did lol so two of us together riding should be a laugh!
Post by rdorvfr on Oct 4, 2011 10:16:47 GMT 1
good job!!!
lcolin
Post by lcolin on Oct 4, 2011 19:26:24 GMT 1
you're definatly going to turn a few heads when you ride out together, and make a few ears bleed!! Can't wait to see 'em both out, up and running.
Post by smads on Oct 4, 2011 23:42:58 GMT 1
i cant wait either..... im building an electronic speedo into my lc clock. both brakes to bleed. fit pump and lines. set pv travel with computer. fit throttle cable. fill with oil and fuel and try start the bugger
Post by christyres on Oct 5, 2011 20:04:20 GMT 1
more pics Attachments:
Post by christyres on Oct 5, 2011 20:09:45 GMT 1
sweet pipes Attachments:
Post by christyres on Oct 5, 2011 20:14:42 GMT 1
aprillia arm Attachments:
Post by christyres on Oct 5, 2011 20:27:49 GMT 1
,, Attachments:
Post by christyres on Oct 5, 2011 20:29:54 GMT 1
, Attachments:
lcolin
Post by lcolin on Oct 5, 2011 20:44:42 GMT 1
Where did you get the saddle done smads?
Post by smads on Oct 5, 2011 21:06:50 GMT 1
mate i dont know who made it or wot it is ,it was in a job lot of bits and even the owner had no idea...sorry
Post by billy on Oct 7, 2011 1:17:10 GMT 1
Damn that rocks, give us a video of it!!!
Post by smads on Oct 7, 2011 7:42:42 GMT 1
I will when it's running
Post by smads on Oct 14, 2011 20:46:29 GMT 1
Anyone know of ignetec ignition setup?? Who can load and do map as I've just found out my ignition is empty.... :-(
Post by smads on Oct 28, 2011 10:59:59 GMT 1
Well just found out my TSS stuff maybe all bad..... Ain't started it yet so I'm gonna get new ignition and see if it stays together . Nice to find out it maybe wrong ehh
Post by dusty350 on Oct 28, 2011 11:19:54 GMT 1
Hi I read the various threads about TSS last night. Real shame it has all gone wrong for them. Not all the parts Steve supplied are gonna give you trouble though. He has listed in his posts over on the US forums which parts should be ok. Main issues are with 90 degree cranks, Fcr carbs and 485 cylinders. I have never used TSS, but it's a real shame when a firm that is in business to make our bikes better has such problems. There is a lot of cat fighting going on on the US forums, but anyone interested can start here; www.rzrd500.com/phpBB2/viewtopic.php?t=7287Hope your build works out ok. It's an awesome project. Regards Dusty
Post by JonW on Oct 28, 2011 11:54:26 GMT 1
smads, I emailed Chris this info, but you should contact Ghezzi as he can help you sort your engine m8.
r1olly
Post by r1olly on Oct 28, 2011 12:14:34 GMT 1
hope you sort your probs out, am watching this build...gonna be awesome when done! good luck!
Post by Norbo on Oct 28, 2011 21:46:46 GMT 1
I realy like the red on this bike and i was just looking at one of them temp guages for the water hose the other day but wasnt sure what size to go for .
Post by smads on Oct 29, 2011 17:42:46 GMT 1
hi norbo
temp gauge is 57mm long middle section is 22mm hose connectors are 19mm
from banshee atv
thing is on lc it will be tight as me and chris moved our rads 10mm forward at the bottom but you still maybe able to squeeeeeeze one in
Post by oldelsieboy on Oct 29, 2011 20:31:36 GMT 1
i was just looking at one of them temp guages for the water hose the other day but wasnt sure what size to go for . Isnt it fitted in the wrong end of the cooling system, surely the correct temp reading is taken after the coolant has been thro' the motor & before the radiator. OEB
Post by smads on Oct 29, 2011 21:40:40 GMT 1
so your gonna put it under your tank then ehh...what u gonna do jump off at the lights to have a peek......mate theres no other place to put it and thats where atv put them....yes i suppose it would read bit cooler but it gives you a good reading of how hot the water is thats fed to your motor!
Post by christyres on Oct 29, 2011 23:19:59 GMT 1
Both mine and smads bike run both inline and clock temp gauge so ther for givin a full proof way of keeping an eye on what's going on with the temperature around the complete cooling system,most of all they look the nuts and keep people asking silly questions about them lol
