Post by Norbo on Sept 20, 2011 9:56:37 GMT 1
When fitting a KR1S front end you can use rgv 250 vj21 yokes as the are the same dia forks and same centers on the yokes so all you need to fit the yokes is the 5mm spacer and adjust the lock stops then the KR1S forks fit straight in.
You can use the KR or KR1s yoke but to make it look right you need to do a stem swop Spodon440 on the site can do this . If you dont you need to space up the top yoke as its way to long and looks nasty.
thanks to scott mate for info
