Post by daz on Oct 30, 2007 20:14:05 GMT 1
Is powder coating best for a lasting finish for calipers
Post by vin on Oct 30, 2007 20:51:42 GMT 1
Is powder coating best for a lasting finish for calipers Yep! Not everyones cup of tea though as some say it looks too thick I think they look cool myself ;D
Post by tonkatoy on Oct 30, 2007 23:25:00 GMT 1
i agree with Vin
Post by Shytalk on Nov 2, 2007 19:54:57 GMT 1
Is powder coating best for a lasting finish for calipers Yep! Not everyones cup of tea though as some say it looks too thick I think they look cool myself ;D Depends on who you get to coat them, a decent coater will only put a thin coat on
Post by bare on Nov 2, 2007 20:56:22 GMT 1
Be carefull Poweder coatings are thick and some are thicker than others. But ..all.. will cause serious "fit" problems where clearances are critical. There.. are.. paints designed for Calipers that do not have the problems, look, or cost of Powder.
Post by vin on Nov 2, 2007 23:13:08 GMT 1
Be carefull Poweder coatings are thick and some are thicker than others. But ..all.. will cause serious "fit" problems where clearances are critical. There.. are.. paints designed for Calipers that do not have the problems, look, or cost of Powder. I disagree on the fit problem...... never had a problem with the three pairs that I have had done
Post by Dirtbag on Nov 4, 2007 10:38:24 GMT 1
I must admit.............I've never had any brake calipers powder coated.............never found the need. If you use good quality paints you can get exactly the same effect for a fraction of the cost of powder coating. Plus I always worry about the effect high temperature baking has on the alloy.................it must warp them slightly
Post by Norbo on Nov 5, 2007 9:39:51 GMT 1
I am the same as dirtbag
I have never had a set powder coated . I allways just spray them or polish them.
However i have had calipers that have been and they have fitted no problem .
Post by tonkatoy on Nov 7, 2007 20:54:14 GMT 1
looks like we have a stalemate go with what you feel is right mate
Post by jambo on Nov 9, 2007 22:56:32 GMT 1
another option is anodising them...they do lots of colours now..
