Post by lovely on Jul 11, 2007 20:36:10 GMT 1
in the process of reassembling the calipers on my mk2 125. have bled the system to spray them up. the pads are only a couple of mill apart at the moment. when i refill them, will they resume the original setting, or do i need to push them back in? if so whats the best method?
Post by vin on Jul 11, 2007 20:58:16 GMT 1
You will need to prise them apart a bit more! before you do make sure the fluid level in the reservoir is not too high as fluid will go everywhere I found a tire lever good for this but any flat thinnish bit of metal should do!
Post by lovely on Jul 12, 2007 17:47:45 GMT 1
vin -there is no fluid in the system, have drained it all out. did notice when i took them apart there was a felt? washer on the lower connector bolt - will i need this, as it fell in the container i was draining them into...
