grunt
Post by grunt on Aug 23, 2010 22:47:31 GMT 1
you may need THESE ;D ;D ;D ;D fingers crossed i will s**t myself when its run in and i test it properly do i need a high flow fuel tap or should i be ok if its on full throttle for a long period of time i will need it if not i doubt it
Post by billy on Aug 24, 2010 5:23:01 GMT 1
I think the original fuel tap is fine but you may wanna keep an eye on the hose ID. It looks like you already have a reasonable sized hose though so you're probably fine. Btw, looking at the pics of the split engine, I noticed the main bearings are the same size, (or at least very close) isn't the right hand bearing ID suppose to be smaller then on the left bearing? Maybe the crank shaft is thicker then a original 125 crank?
grunt
Post by grunt on Aug 24, 2010 7:54:47 GMT 1
Btw, looking at the pics of the split engine, I noticed the main bearings are the same size, (or at least very close) isn't the right hand bearing ID suppose to be smaller then on the left bearing? Maybe the crank shaft is thicker then a original 125 crank? ur eyesights good i had to change this as i did get the wrong one but bearing place is about 2 miles away so not a problem ;D
Post by LC'Adam on Aug 24, 2010 13:52:48 GMT 1
Carb looks good on grunt, have been very busy so spring will be posted some time this week . Looks great mate, can't wait to see you get it running ;D. Adam
grunt
Post by grunt on Aug 24, 2010 22:21:22 GMT 1
yes adam vids as soon as the next surprise arrives just got in after spending the day finishing the internals off clutch ect oil seal and few other bits and refitting to the bike with the help of my misses this is what the engine looks like with the clutch fitted and the engine back in the bike ;D
Post by twostroker on Aug 24, 2010 22:48:10 GMT 1
when its run in you sould defenetly get a dyno run.a power run is only cheap it would be great to see it make over 30 bhp
grunt
Post by grunt on Aug 24, 2010 22:52:26 GMT 1
when its run in you sould defenetly get a dyno run.a power run is only cheap it would be great to see it make over 30 bhp looking at the power chart that come with the big bore kit it says that with a 10w carb and standard pipe airbox ect it makes 28bhp and 8,000 rpm so should be over 30 i recon ;D
Post by LC'Adam on Aug 25, 2010 0:02:19 GMT 1
Looks spot on might have to save some pennys to do that to mine one day. Also, very kind of your missus to help ya lol ;D
Post by lcowner on Aug 25, 2010 10:01:30 GMT 1
dat engine looks sweet....
Post by carlos on Aug 25, 2010 17:35:27 GMT 1
I LOVE the clear float bowl!
Where did that come from?
Post by bubba on Aug 25, 2010 17:58:25 GMT 1
that looks so trick! and that float bowl is first time i have seen a one.
Post by twostroker on Aug 25, 2010 18:21:38 GMT 1
that is 1 very trick looking 125lc engine fella,maybe a alloy kicker to finish it off?
grunt
Post by grunt on Aug 25, 2010 19:54:29 GMT 1
thanks everyone getting there now this carb is proving to be a nightmare to set up never played around with float height ect well all in good time she will rev right round cleanly ;D
Post by looey on Aug 25, 2010 20:11:59 GMT 1
R u annoying them neighbours again revving your bike up ;D ;D
grunt
Post by grunt on Aug 25, 2010 20:14:38 GMT 1
yes she came out earlier and said i dont normally moan but your stinking my kitchen out and i have a thumping headache f***king muppet lol i aint appologising as i didnt do anything wrong grunt
Post by twostroker on Aug 25, 2010 20:26:06 GMT 1
thanks everyone getting there now this carb is proving to be a nightmare to set up never played around with float height ect well all in good time she will rev right round cleanly ;D my 175lc used standard main jet and 1 down on the pilot jet if it helps
grunt
Post by grunt on Aug 25, 2010 21:23:03 GMT 1
ive got a pwk30mm flatslide d-shape carb as piccys above just set everything as per nickfubars setup post and am gonn get few more jets and play around ;D
Post by lcowner on Aug 25, 2010 21:45:52 GMT 1
can u get those clear float bowls for a 4lo ect..?
grunt
Post by grunt on Aug 25, 2010 21:46:59 GMT 1
only a pwk28 or some sortta dellorto mate
just found out why my carb is playing up 1 bit missing only little but its enough ;D
Post by billy on Aug 26, 2010 12:11:48 GMT 1
Hey grunt (Or whoever else can/want to answer..) i have a question. How do you go about putting the engine back together? On a single cylinder engine like this, I usually put the gearbox assembly into the right hand case and then put the left case over, but is it better to do the opposite on the RD engine? Any tips and hints to think about? PS: I'm not a complete nutjob when it comes to engines, but the 125 engine isn't very familiar yet, I've only taken it apart so far but it's getting time to put it back together again.
Post by mellow on Aug 26, 2010 16:51:16 GMT 1
Hi billy. Manual says to lay left hand case down.......assembly gear parts/balance shaft/crank etc into left case then fit right hand case onto it (so clutch side is top)
grunt
Post by grunt on Aug 26, 2010 18:51:18 GMT 1
update now took it for an mot today straight throught with flying colours except the fact i got an advisory for a noisey exhaust haha no bs stamp oh well ;D
carb bit is on way tomorrow god she shifts even bodged up well should be going on saturday night after some tinkering
got up this mornging and throttle cable went t**s up so i made one to the exact size pretty impressed tbh ;D
Post by billy on Aug 27, 2010 10:57:54 GMT 1
Hi billy. Manual says to lay left hand case down.......assembly gear parts/balance shaft/crank etc into left case then fit right hand case onto it (so clutch side is top) Thank you sir, very helpful.
grunt
Post by grunt on Aug 28, 2010 19:01:54 GMT 1
right got the part for the carb through runs ok atm hesitates at about 4-5 and half thousand revs then goes through but my god its fast front wheel wants to lift in 1st and 2nd but im still running in so only checking it revs smoothly ect then i will do my 300 miles ;D HERE YOU ARE EVERYONE CARB STILL NEEDS SET UP COMPLETELY www.youtube.com/profile?user=pugwash2424#p/a/u/0/XkiuJLij-7g
Post by richardroberts on Sept 4, 2010 13:57:33 GMT 1
looks sweet m8
Post by billy on Sept 5, 2010 18:01:20 GMT 1
I hope you'll make an onboard vid later, and make sure to get it on the pipe lol. I wanna see it fly.
