Post by midlifecrisisrd on Oct 29, 2010 17:48:05 GMT 1
Sorry to give you cause for doubt... maybe drop Kenny an email but im sure i read it would fit. I planned to fit one on my 57V with the same pipes if i can make it fit. Tho i may have to move the spring as you did (can you detail how you did that by the way?) I will also want to fit a center stand to my LC with pipes so that may get interesting depending on which engine goes in there and which pipes... hmm... There is a pic in this thread, I cut off the spring locating peg on the rear of the stand then drilled a 5mm hole from the rear on the stub all the way through and M6 tapped it and put a bolt through with a lock nut on the rear. Then did the same drill and tap on the stand bracket exactly where the lug from the spring was and bolt again and use the original spring. Job done, Steve.
Post by JonW on Oct 31, 2010 0:16:02 GMT 1
Thanks Steve, I thought thats what you did from the pics, but always good to know for sure. I will need to do this mod i think to fit my pipes as well.
stevew
Post by stevew on Nov 6, 2010 9:45:31 GMT 1
thats a lovely looking bike mate
Post by midlifecrisisrd on Nov 17, 2010 19:13:10 GMT 1
Chain fitted and front muddy on, just got to find somewhere to mount the horn. Steve.
Post by Deleted on Nov 18, 2010 10:45:58 GMT 1
Very nice. I could look at that all day. I Love the rear mud guards
Post by tsa on Nov 20, 2010 12:27:39 GMT 1
Very nice indeed, good neat fitting of the parts make it look factory etc. I thought that Kenny's exhausts could be fitted with the centre stand in place, maybe i misread that but i was sure of it... hmm... They can be fitted with the std centre stand but the bike has to be bog standard.
