Post by JonW on Apr 20, 2023 13:37:46 GMT 1
Are you just desperate to do some spannering or something? haha... The voices in my head are telling me to swop the stator out ! pmsl, the voices on the forum are more numerous... and they are calling for a battery swap lol
Post by robg on Apr 20, 2023 14:43:28 GMT 1
I have moved over to lithium batteries, they are lighter and hold charge for longer
Post by alankelly on Apr 20, 2023 14:58:16 GMT 1
I have moved over to lithium batteries, they are lighter and hold charge for longer Yes I have looked into lithium batteries I did buy a JMT lithium ion battery, but swapped it out for a gell one as heard stories of fires due to overcharging due to old style regulators? I know it has inbuilt BMS (battery management system) but just was not happy to take a risk? So itβs on the shelf for now, but most likely wonβt go to waste as it will be fitted in the Tigcraft bike, as was really shocked by the lightness of the battery and it sizeπ Would be interested if others have fitted a lithium battery and which one they fitted (Manufacture/model) and if they are using the original regulator rectifier or have a more modern charging system fitted like the Vape system that I intend to install on the Tigcraft project. Best wishes Al
Post by headcoats on Apr 21, 2023 11:19:27 GMT 1
Just ordered a Yuasa battery from Tanya batteries for next day delivery.
I will keep you posted π
Post by arrow on Apr 21, 2023 11:26:27 GMT 1
If you've had the stator off an LC, don't forget you will need to set up the timing again.
Post by headcoats on Apr 21, 2023 11:48:36 GMT 1
It's an LC hybrid with ypvs engine π
One good thing about it as the stator plate is fixed
Post by arrow on Apr 21, 2023 11:49:25 GMT 1
π
Post by headcoats on Apr 21, 2023 16:08:41 GMT 1
How about someone like Dusty do a pic thread on testings stator,reg/rec
Show step by step testing and what positions you need to Set the multimeters too π€
Post by headcoats on Apr 22, 2023 13:19:54 GMT 1
OK charged battery and is At 12.78
At idle it's 14.19 At 2000rpm it's 14.08 At 3000rpm it's 14.10
So a tiny drop when revving Does this sound good or no gain in volts as the revs rise a problem ?
Post by arrow on Apr 22, 2023 13:43:10 GMT 1
Anything over 14v is fine. No problem. Try again with some load on the circuit, ie turn the lights on.
Post by midlifecrisisrd on Apr 22, 2023 13:50:48 GMT 1
The clue is in the name
Sounds regulated to me π€ͺ
Post by arrow on Apr 22, 2023 13:54:56 GMT 1
Some of the Japanese cars from the 80's regulated the voltage to just over 15v. I've never understood why that was necessary. Anyone?
Where as some of the Lucas alternators were regulated down to around 13.8v.
Both using a battery of 12v, nominal.
Post by headcoats on Apr 22, 2023 14:03:29 GMT 1
Lights on 12.25 idle 14.70 2000rpm
So with lights on I got highest reading
Post by arrow on Apr 22, 2023 14:05:35 GMT 1
Lights on 12.25 idle 14.70 2000rpm All normal. This generation/type of charging system will rarely be able to 'keep on top' (when loaded) at idle revs.
Post by beardy on Apr 22, 2023 14:12:09 GMT 1
Itβs fineπππ»
Post by JonW on Apr 22, 2023 14:21:03 GMT 1
Agree with the others, its fine and thats how these were done in the day, only added power off idle to combat the drain... lots of cars/bikes like that. Where as some of the Lucas alternators were regulated down to around 13.8v. Er, Gary, the 'Prince of Darkness' years... they regulated down to 0v not long after being put into use lol EDITED: personally not had much of an issue with Lucas products, but know many did... so that was me joking really. Anyway, pleased Martin took the forum advice and did the right thing.
Post by headcoats on Apr 22, 2023 14:38:50 GMT 1
Cheers everyone and thanks for steering me in the right direction, even though I had removed the flywheel π€£
Post by headcoats on Apr 22, 2023 15:05:38 GMT 1
Even though my old Varta battery and new Yuasa battery had same codes,the Yuasa was a good tight fit compared to the Varta
Post by elsiefan on Apr 22, 2023 18:18:45 GMT 1
Cheers everyone and thanks for steering me in the right direction, even though I had removed the flywheel π€£ Following the old adage "If you cant' fix it with a hammer, it's an electrical problem!" π
Post by headcoats on Apr 22, 2023 18:37:11 GMT 1
Mine is if it ain't broke,take it apart anyway π€£
