Post by 4l04ever on Jan 7, 2024 18:40:26 GMT 1
Post by 4l04ever on Jan 7, 2024 18:42:42 GMT 1
Fired up 3rd kick
Post by donkeychomp on Jan 8, 2024 22:17:56 GMT 1
Brilliant! Nicely done Rob.
Post by 4l04ever on Jan 30, 2024 20:16:26 GMT 1
Popped the tank on
dex46
Post by dex46 on Jan 30, 2024 22:00:03 GMT 1
Excellent looking build he will be well chuffed on how it’s come out 👍👍
Post by 4l04ever on Jan 30, 2024 22:15:14 GMT 1
Just a few little jobs and she will be done! :-)
Post by 4l04ever on Feb 2, 2024 20:44:22 GMT 1
Changed the left engine cover as the threads for the adjuster cover needed sorting out. Fitted gear lever.
Post by 4l04ever on Feb 6, 2024 0:07:57 GMT 1
The five minutes brake pad fitting job took a lot longer as the Ferodo pads needed some adjustments. I had to repaint the machined surfaces.
Post by 4l04ever on Mar 2, 2024 0:21:09 GMT 1
Left seat catches refurbed. One for number 4 and one for number 14
Post by 4l04ever on Mar 2, 2024 19:26:21 GMT 1
Fitted rear sprocket locking tabs.
Post by 4l04ever on Mar 2, 2024 19:27:37 GMT 1
Fitted refurbished left seat catch.
Post by 4l04ever on Mar 2, 2024 19:29:18 GMT 1
Front calipers and brake lines fitted.
Post by JonW on Mar 5, 2024 4:07:50 GMT 1
Good jobs there Rob, nice work as ever.
Post by 4l04ever on Mar 9, 2024 18:54:19 GMT 1
crigar
Member is Online
Post by crigar on Mar 11, 2024 16:26:14 GMT 1
Le numéro 4 est... vivant ! As we say in France: As long as it's smoking, it's getting grease.
Post by 4l04ever on Mar 25, 2024 0:49:06 GMT 1
Took for it's 2nd test drive.
Post by 4l04ever on Apr 6, 2024 22:15:23 GMT 1
Post by 4l04ever on Apr 17, 2024 19:40:21 GMT 1
I have took the bike out on Saturday and the front end is much nicer now. I am running 16mm preload spacers, and filled with 15W fork oil. Filled to 90mm from the top while compressed with no springs fitted.
Post by urbantangleweed on Apr 17, 2024 19:42:19 GMT 1
Top work Rob, well done.
Post by 4l04ever on May 3, 2024 19:15:54 GMT 1
Weather permitting, I will be riding this bike over to its new owner tomorrow. davidh
Post by 4l04ever on May 4, 2024 21:29:45 GMT 1
Gone :-) :-(
Post by urbantangleweed on May 7, 2024 11:05:37 GMT 1
Fitted modified aftermarket throttle cable. Oil pump lined up perfect 😀 Hi Rob, out of interest, do you know what the correct outer length of the oil pump part of the cable should be and is it the same for LC and PV?
Post by 4l04ever on May 7, 2024 17:29:52 GMT 1
Not sure about YPVS cables as never used one.
I used a Hi-Level throttle cable and cut off about 8.5mm of the adjuster sleeve. Will post a pic of the piece cut off plus 1mm for the cutting disc width.
You also have to file the flange on the end of the pipe so it drops into the recess on the top of the clutch casing.
Post by 4l04ever on May 7, 2024 17:31:14 GMT 1
Pic
Post by fletche36 on May 7, 2024 18:53:16 GMT 1
Not sure about YPVS cables as never used one. I used a Hi-Level throttle cable and cut off about 8.5mm of the adjuster sleeve. Will post a pic of the piece cut off plus 1mm for the cutting disc width. You also have to file the flange on the end of the pipe so it drops into the recess on the top of the clutch casing. I absolutely applaud your ingenuity. You have potentially saved me a good few quid there. Thanks.
davidh
Post by davidh on May 8, 2024 17:44:40 GMT 1
So after an absence of a mere 34 years, today was my return to the motorbiking fold on Number 4 LC! What an absolutely superb job Rob has done on this bike, above and beyond my expectations. I wanted a very nice example LC as that was out of my reach when I was younger and perpetually short of money, so it's nice to have such great bike now!
