Post by stusco on Jun 3, 2022 11:24:09 GMT 1
My PWKs get oily here too, never really caused any issues Ill check mine this afternoon π garage timeπ
Post by headcoats on Jun 3, 2022 11:25:30 GMT 1
Post by arrow on Jun 3, 2022 11:46:46 GMT 1
But is the expansion bottle not there as a system checker If you fill it to the centre of the min/max it in normal use should stay there and should be part of your usual routine checks If the head is starting to leak the level will be higher as the excess pressure in the cooling system and the introduction of air will make the level rise If you have a coolant leak that is not excessive the level will drop Nearly every vehicle has them, there must be a reason for them Running with it empty is another thing, that's a choice for whatever reason you have Steve Most Japanese cars used the same system, ie a non pressurised, vented header tank. Most cars now use a fully pressurised system (including the header tank with air space that's compressible) and no vent. It's also the main reason why you shouldn't use red (more modern) coolant in the Yamaha Lc range.
Post by Tobyjugs on Jun 3, 2022 11:52:47 GMT 1
Each to their own π And before anybody says it I know a Tesla does not have an exp tank π€£ Steve Is it possible to equate a battery as being similar to an expansion tank
Post by tony2stroke on Jun 3, 2022 11:54:24 GMT 1
But is the expansion bottle not there as a system checker If you fill it to the centre of the min/max it in normal use should stay there and should be part of your usual routine checks If the head is starting to leak the level will be higher as the excess pressure in the cooling system and the introduction of air will make the level rise If you have a coolant leak that is not excessive the level will drop Nearly every vehicle has them, there must be a reason for them Running with it empty is another thing, that's a choice for whatever reason you have Steve Most Japanese cars used the same system, ie a non pressurised, vented header tank. Most cars now use a fully pressurised system (including the header tank with air space that's compressible) and no vent. It's also the main reason why you shouldn't use red (more modern) coolant in the Yamaha Lc range. Please elaborate on the RED coolant.
Post by arrow on Jun 3, 2022 12:05:35 GMT 1
Colour refers to type, ie chemical make up.
Red coolant is good stuff, with a 5 year fill life. It works great, but with one draw back. It doesn't like being constantly exposed to fresh air (oxygen is the bad boy here). This shortens its normally long (anti corrosive) life.
In a fully sealed system under normal circumstances it is never exposed to fresh air.
Post by stusco on Jun 3, 2022 12:47:05 GMT 1
My PWKs get oily here too, never really caused any issues Ill check mine this afternoon π garage timeπ Mine are oily π
Post by 17again on Jun 3, 2022 13:17:16 GMT 1
Colour refers to type, ie chemical make up. Red coolant is good stuff, with a 5 year fill life. It works great, but with one draw back. It doesn't like being constantly exposed to fresh air (oxygen is the bad boy here). This shortens its normally long (anti corrosive) life. In a fully sealed system under normal circumstances it is never exposed to fresh air. this same bike as ready/ pinky coolant inside which i thought was strange. maybe i should replace this
Post by 17again on Jun 3, 2022 13:17:29 GMT 1
Ill check mine this afternoon π garage timeπ Mine are oily π thanks stu
Post by 17again on Jun 3, 2022 13:17:53 GMT 1
this could help for sure thanks.
Post by tony2stroke on Jun 3, 2022 13:20:30 GMT 1
Colour refers to type, ie chemical make up. Red coolant is good stuff, with a 5 year fill life. It works great, but with one draw back. It doesn't like being constantly exposed to fresh air (oxygen is the bad boy here). This shortens its normally long (anti corrosive) life. In a fully sealed system under normal circumstances it is never exposed to fresh air. I got all confused a while ago, people going on about silicates causing problems with RF900 water pumps, 3 different colours, I think, green, blue, pink (red) I just stuck with what was in it, green. Never got a satisfactory answer as to why blue was not good enough, gave up trying to understand, and just fill with whatever is in the car/bike when emptying. Be nice to have a laymen's answer we can all understand.
Post by arrow on Jun 3, 2022 13:58:25 GMT 1
Problem now, Tony, is that coolant is rapidly becoming like oil, manufacturer specific.
Halfords for example has at least 12 different types of 5/30 oil. Crazy!
Post by chrisg on Jun 3, 2022 22:16:17 GMT 1
Problem now, Tony, is that coolant is rapidly becoming like oil, manufacturer specific. Halfords for example has at least 12 different types of 5/30 oil. Crazy! Apparently the different types of oil is to do with the particulate filters(DPF) and the blocking of them, im not convinced. Anti freeze may affect seals or the ally in the system, but again not fully convinced.
