Post by dusty350 on May 20, 2022 13:12:45 GMT 1
Posted this morning - hopefully you will get it tomorrow. Good luck Dusty
fabiostar
the older i get the faster i was.
Post by fabiostar on May 20, 2022 17:44:06 GMT 1
good to see you made it here Al.. this is gona be fun to watch!!!!
Post by steve63 on May 20, 2022 21:20:18 GMT 1
Dusty well done . How do you stop the shed fairies and pixies moving stuff you know will be useful one day . They do that to me all the time With me it's nothing to do with Pixies or Fairies. I put something somewhere then a couple of weeks later I have no idea where that was. I offered my youngest lad a couple of wood planes that my Father in Law had given me only to slowly realise whilst looking for them with him watching that I had already given them away to the eldest lad. Woops 😁
amcq46
Post by amcq46 on May 21, 2022 9:13:01 GMT 1
good to see you made it here Al.. this is gona be fun to watch!!!! Cheers Rob, thanks for pointing me In this direction.
amcq46
Post by amcq46 on May 23, 2022 20:32:31 GMT 1
MANY, many Thanks dusty, it arrived today👍👍👍👍🍺🍺🍺🍺🍺😄😄😄
Post by dusty350 on May 23, 2022 20:41:31 GMT 1
Glad you got it ok Good luck - hopefully you will get the gearbox working ok now Dusty
amcq46
Post by amcq46 on May 25, 2022 16:31:25 GMT 1
Clutch all back in😄 then spotted that whoever painted the clutch side engine cover didn’t bother to mask the gasket face ☹️!! So 2hrs of scraping needed to get back to the metal😭 I used some gasket compound on that side to compensate for any imperfection and put a light coat of grease on the engine side so hopefully the gasket will pull off next time I have to take the cover off. Oh and it now selects the gears👍
Post by steeley on May 25, 2022 17:16:37 GMT 1
Great stuff , result .
Dave B
Post by Dave B on May 26, 2022 9:28:37 GMT 1
My neighbour has literally a stack of RD400 barrels and crankcases in his garage. I'd estimate over twenty sets. It would be worth a trip to Staffordshire if you are interested.
Post by 350smoker on Jun 14, 2022 19:36:10 GMT 1
amcq46
Post by amcq46 on Jan 26, 2023 22:05:36 GMT 1
Good news…. The project is getting back out of its stalled state…. Life, daughters wedding, a month in New Zealand, then Christmas….. usual excuses.
So I had spent a fair amount of time trying to diagnose why I didn’t have any spark from the FEMSA / Rex Caunt ignition system, but I eventually gave up and purchased an Elextrexworld rotor, stator, CDI & coils designed for air cooled Race TZ Yamahas, but also suitable for the RD.
That’s all fitted now and the next step is to work out a fuel tap for the PW50 gas tank that is fitted and see if it will start.
amcq46
Post by amcq46 on Jan 26, 2023 22:08:41 GMT 1
stoney
Post by stoney on Jan 27, 2023 18:18:23 GMT 1
Loving this thread. Something different.
amcq46
Post by amcq46 on Jan 28, 2023 21:40:22 GMT 1
Oh yes, it runs. Crackles and barks like a demented beast, I won’t be popular on my road when I get it out for a test ride Unfortunately the throttle cable broke at the twistgrip so no riding today. So spent the afternoon making a new cable end with solder. I drilled a 6mm hole in a piece of wood, cut a slot for the cable go in so its cleaned and frayed end is In the middle of the hole, put a 6mm drill tail back in the wood from below to set the required width of the cable end and then filled it with solder….. worked a treat So might try and see if it will roll tomorrow
Post by dusty350 on Jan 29, 2023 9:11:30 GMT 1
Fingers crossed !! We need pics though Dusty
amcq46
Post by amcq46 on Mar 13, 2023 18:43:05 GMT 1
Good news is I have tracked down the original Tuner (Harry Barlow) who did the original work in 1988, and more good news is that he still has his 400 drag bike and a supply of parts alongside his current scooter tuning business. So Harry asked me to strip it all down and measure the key parameters to help him understand what he did back then and from there we can work together to get it set up and racing. ….. so rather than rushing to the dyno its all coming to bits and getting measured. In the process of doing the measurements I have built up a leak tester and I just tested that on the RH cyl, as I haven’t taken it apart ….. it leaks like a sieve . So I just took the primary drive gear off and can see a few problems with both the seal at the end of the keyway, and the washer on the end of the crank. I will post some pictures later and go back and look at Dusty build thread so I can see if I am missing anything here
amcq46
Post by amcq46 on Mar 13, 2023 18:47:02 GMT 1
amcq46
Post by amcq46 on Mar 13, 2023 19:42:21 GMT 1
Part #26 is the seal I need, but it’s showing as unavailable so far. I notice that dusty350 didn’t have one on his 400E rebuild, so perhaps I can work round this with some sealant on the joint and key.
Post by dusty350 on Mar 13, 2023 20:01:54 GMT 1
The later models didn't have the seal. I always build any engine with a new square key and 3bond applied to the 4 sides of the key to help prevent leaks. Important the groove on the end of the crank the key sits into is good too of course Dusty
amcq46
Post by amcq46 on Mar 13, 2023 20:05:29 GMT 1
Found the seal (assume a pattern part) on yambits, so will get that and also add the sealant to the key.
I will get a new Belleville washer, as the one i took out it was dented on one side so not the normal cone shape
amboyy
Post by amboyy on Mar 30, 2023 18:44:51 GMT 1
Once you have up and running it might make a good land speed bike depending on rules and present configuration. Very nice looking bike.
amcq46
Post by amcq46 on Feb 8, 2024 21:31:31 GMT 1
Since my last flurry of activity and posts, the project went off teh boil for a while, but it is now back as a focus and i intend to get to the Straight liners Run What You Brung meeting at Santa Pod on April 7th. So the work now completed is - a full rebuild of the air shifter, - rear shock removed and a a lock up bar in its place. - structural bracing to make sure the chain adjusters don’t get bent under an aggressive launch. - purchasing some seriously expensive high octaine C16 fuel. - full day on the dyno at 2T engineering in Banbury to get the jetting and ignition dialled in. The main jets that were in the bike when I got it were 500’s, but we ended up back down at 280 to get it revving through with a good AFR at all throttle openings, we then advanced and retarded the ignition to get the best compromise of peak power and overrev. Power is 65bhp at 10,700rpm and 33ftlb at 9700rpm and the curve looks good. I had hoped for over 70, but this looks like a safe tune and should be more than enough for a a starting point into drag racing. What still needs done is: - work out how to pull down the front forks to reduce the tendency to wheelie off the line. - sort out some kind of chain guard so the bike will comply with the regulations for the RWYB class.
amcq46
Post by amcq46 on Feb 8, 2024 21:37:26 GMT 1
Post by reedpete on Feb 9, 2024 12:13:04 GMT 1
I know it will be only full chat for a few seconds but I’m interested that Andy was ok with revving to 11.5 with a 400 crank. That’s TZ350 revs… Or is that just dyno exploration? I would have thought Rev limiter at 10.8 would be prudent . Should still be plenty of power across the gear spread you need.
amcq46
Post by amcq46 on Feb 9, 2024 12:24:36 GMT 1
I know it will be only full chat for a few seconds but I’m interested that Andy was ok with revving to 11.5 with a 400 crank. That’s TZ350 revs… Or is that just dyno exploration? I would have thought Rev limiter at 10.8 would be prudent . Should still be plenty of power across the gear spread you need. Thanks that’s a good point on the rev limit for the crank, I will talk to both Harry and Andy to see what their thoughts are…. Although I am not sure the ignition system has a rev limit feature, so I will have to manage that manually
amcq46
Post by amcq46 on Mar 13, 2024 23:39:49 GMT 1
Well that’s a huge step backwards! With the 1st drag outing less than a month away, I thought i would start her up, get her up to temperature and make sure all the basics are still working. After wam up, did a couple of hard starts from about 3 to 4000 revs just to see it it wheelies or spins (it spins) and then the engine note changed with a new metallic sound from the left hand pot. Back on the bench and took the L/h head off to see some metallic particles in the combustion chamber Further strip down to find the back of the piston has broken up So now I need to split the engine to get the rest of the bits out and also the joy of tracking down a 40yr old piston which may or may not be from a DT175. The engines out and on the bench and I have spent hours on the internet tracking down Yamaha pistons that are marked like this one anybody know how to decode the piston numbering 2A700? Is it DT175 or IT175 and what year? Let’s see how far get before the deadline of April 7th
Post by dusty350 on Mar 14, 2024 7:56:06 GMT 1
Google is your friend. Type in Yamaha 2A700 Piston into Google and it comes up with DT175 Best stock up on a few - it can be a very expensive hobby Good luck
Post by tony2stroke on Mar 14, 2024 13:07:33 GMT 1
As Dusty said, 2A7 is prefix for Dt175, though parts could also be used across a range of machines, ie piston also for It175, but the prefix is for DT175, yamaha do this s lot.
HTH
Post by 4l04ever on Mar 14, 2024 18:31:25 GMT 1
Apparently, there are two versions of DT175 pistons. Early and Late???
amcq46
Post by amcq46 on Mar 14, 2024 19:31:00 GMT 1
Thanks all … yes when i look at images of various DT175 pistons, some have much smaller windows on the back, so i am trying to work out which year i need to look for
