Post by lcmarky on May 30, 2022 12:27:33 GMT 1
Post by lcmarky on May 30, 2022 12:29:06 GMT 1
Each time I pick up these yokes I think they're just so heavy & decided to do something about it and make my own.. This should be fun. Yokes material by KTM Marky, on Flickr
Post by headcoats on May 30, 2022 12:37:45 GMT 1
If it's RGV then the yoke is made from pig iron !
Post by lcmarky on May 30, 2022 12:46:50 GMT 1
If it's RGV then the yoke is made from pig iron ! it is.. Ally top part that with a little tuning will be OK.
Post by lcmarky on May 30, 2022 12:49:42 GMT 1
Post by dusty350 on May 31, 2022 6:25:27 GMT 1
Only just read this thread through. Awesome skills, and attention to detail So good when you can fabricate your own parts to such a high standard. This will be another fantastic build And get well soon Dusty
Post by shaunthe2nd on May 31, 2022 8:21:44 GMT 1
Nice machine work, looks very satisfying.
Post by lcmarky on Jun 4, 2022 10:42:55 GMT 1
Post by lcmarky on Jun 4, 2022 10:46:12 GMT 1
Post by lcmarky on Jun 5, 2022 19:10:23 GMT 1
I now have some handlebar risers/clamps. Ti bolts to suit on order. Pretty much have the headstock and steerer sorted I think now.
Post by JonW on Jun 6, 2022 1:22:58 GMT 1
Very nice.
I did similar with my clock mounts on my 421LC and recessed them into the top clamp about halfway to get the clocks closer to the bars.
Martin, FYI the base JDM and SP models came with alloy lower triples.
Post by lcmarky on Jun 6, 2022 9:30:38 GMT 1
Very nice. I did similar with my clock mounts on my 421LC and recessed them into the top clamp about halfway to get the clocks closer to the bars. Good thought thx & I'm going to get these yokes fully fitted and set up before I make my own so your point about the clock mounts I'll address when I know where they sit now. I'm using Renthal 758 (I think) bars.. Ti bolts just ordered up for the yokes & I think I'll make myself a new front wheel spindle and get that centred before sending the wheels off for powder coating, so at least then I can try and get the correct offset discs instead of using a spacer ring.
Post by lcmarky on Jun 9, 2022 13:14:10 GMT 1
Post by lcmarky on Jun 9, 2022 13:30:43 GMT 1
..looking at these pictures I think I'll turn off half the thread length and open up the corresponding female thread section to lighten the two parts so it'll have a larger hole looking at it from the outside like the hex end.
I will also run a boring tool up to smooth out the internal surfaces.
Post by lcmarky on Jun 28, 2022 19:12:13 GMT 1
As I wait for powder coated wheels and yolks though I’d have some time on the motor. I think we can call this disassembled. It’s a Fahron tuned 400cc with Banshee pistons and twin 28 Keihins.
Post by lcmarky on Jun 28, 2022 19:15:53 GMT 1
14mm Reamer for the gear selector shaft bush. I didn’t think I had much play on the shaft but what a difference the bush makes.
Happy to help anyone out who wants their case opened up to suit the bush.
Post by lcmarky on Jun 28, 2022 19:20:38 GMT 1
Post by lcmarky on Jun 28, 2022 19:21:23 GMT 1
Post by lcmarky on Jun 28, 2022 19:22:06 GMT 1
I’ve cleaned the mucky paw prints off now.
Post by lcmarky on Jun 28, 2022 19:24:13 GMT 1
Think I’ll pop the motor in and create a bit of work space elsewhere.
Post by lcmarky on Jul 21, 2022 20:17:09 GMT 1
A long delay due to holidays, drinking beer, riding my Ducati and generally doing lots of other things.
Post by lcmarky on Jul 21, 2022 20:18:53 GMT 1
I now have powder coated wheels, new tyres, bearings etc. I’m happy with the perspective of wheel/tyre width thankfully.
Post by lcmarky on Jul 21, 2022 20:20:02 GMT 1
Some new blast media in the cabinet working well.
Post by lcmarky on Jul 21, 2022 20:20:51 GMT 1
Turned up a new bearing spacer for the rear wheel from 303 SS.
Post by jessy03 on Jul 22, 2022 11:00:26 GMT 1
Great skills, wish I had some!
What size bores/pistons are they?
Thanks
Jess
Post by lcmarky on Jul 23, 2022 10:04:11 GMT 1
Great skills, wish I had some! What size bores/pistons are they? Thanks Jess
Post by lcmarky on Jul 23, 2022 10:10:10 GMT 1
Post by lcmarky on Jul 23, 2022 10:11:44 GMT 1
A huge thank you to Andy748 for the GSXR Discs. 👍✊
Rob123
Post by Rob123 on Jul 23, 2022 10:28:58 GMT 1
I'll be getting some of them clocks for mine eventually they do look cool 😎 👌 Top work
Post by lcmarky on Jul 23, 2022 11:52:54 GMT 1
