Post by sharpyg on Dec 23, 2009 21:47:08 GMT 1
Can't use the Tuono shock as bottom can't be enlarged enuff without weakening the outer too much I'll put it back on eBay. Thinking the 99-2001 R6 shock is the way forward now. Just needs that little bit removed from the shock top mount on the frame to clear the bolt on the remote reservoir apparently. Back to eBay it is then ! Lol on the up side, got the front end back from Stinkwheels today. It looks fantastic !!!!
Post by midlifecrisisrd on Dec 24, 2009 10:22:13 GMT 1
bugger.............small issue with the Tuono shock not fitting, bottom bolt/hole arrangement not good, so need to find another any ideas please ? If it's just a matter of opening up the bolt hole ih the shock there is a small engineering firm it Tonbridge that will do it for about a tenner. Every conversion I have seen uses the RGV linkage and either a conversion kit if you don't want to muck about with the frame or new mounting brackets welded on, as I did. There is an optimum distance down and out from the centre of the swing arm spindle to ensure correct operation of the swing arm, on the bottom mount. Does the swing arm have full range of movement with the 31K linkage & still allow the shock to be fitted without fouling. R6 shocks fit, I used the one with the fork bottom mount for the RGV linkage but some years use an eye bottom mount like the 31K shock Sorry I can't be of more help. I bought my chasis already converted but I'm sure it is the 31K linkage with new dogbones made to the right legnth ( rear is jacked up). RD shock fits no problem but have upgraded to a Hagon shock, at least you know the spring and damping rates are right. If I remember right the chain has to be about 4 links longer as well as VJ22 arm is longer. Steve.
Post by sharpyg on Dec 24, 2009 10:51:27 GMT 1
thanks for all the advice guys Stinkwheels/Gibsons have done the rear end conversion so I'm sure it all works, they have 2 bikes with the early R6 shock in which is apparently 5mm longer than the ypvs one and apparently works well
Post by sharpyg on Dec 24, 2009 10:53:27 GMT 1
ajb235
Post by ajb235 on Dec 24, 2009 10:58:00 GMT 1
Any pics of the refurb'd forks and modified rear end? I'm thinking about Stinkwheels for my USDs Jim
ajb235
Post by ajb235 on Dec 24, 2009 10:59:08 GMT 1
Just seen them! Cheers JIm
Post by yoshi1157 on Dec 24, 2009 12:07:39 GMT 1
If you cant open up the hole on the Tuono shock you could use the size bolt that fits the shock and bush the other part down to fit the bolt. Just an idea seeing as you already have the shock.
Post by sharpyg on Dec 24, 2009 12:15:13 GMT 1
If you cant open up the hole on the Tuono shock you could use the size bolt that fits the shock and bush the other part down to fit the bolt. Just an idea seeing as you already have the shock. they looked at that too, but it just doesn't look like it will be strong enough the bolt is pretty weedy !
Post by yoshi1157 on Dec 24, 2009 12:20:09 GMT 1
Aprilia thought it was strong enough
Post by sharpyg on Dec 24, 2009 12:40:31 GMT 1
Aprilia thought it was strong enough I guess so ! lol, but I thing the bottom mount on the 'prillia linkage encloses and reinforces it
Post by sharpyg on Dec 24, 2009 12:41:48 GMT 1
woohoo...........Interlink just delivered my Vapor Stealth and dashboard !
Post by sharpyg on Dec 24, 2009 13:38:52 GMT 1
awesome ! now the postie just turned up with my 'NK' billet dash mount it's just like Christmas !!!
Post by sharpyg on Dec 24, 2009 20:08:51 GMT 1
Cheers Jazz, will do ta Graham
Post by sharpyg on Dec 25, 2009 23:38:57 GMT 1
Vapor 'Stealth' with Dashboard on NK Racing billet mount I'm gonna get the mount anodised black tho' I think
Niz
Post by Niz on Dec 30, 2009 11:49:36 GMT 1
despite the snow and local ice rink roads today, postie got thro' with some more goodies for me ;D Skidmarx RGV carbon front mudguard The YPVS 'VJ22' chain adjusters are done too if anyone wants some ? Yes I will have a pair ,think you asked me on the rd/rz forum. But I no its down for sum time now . How much are they again please?
Post by sharpyg on Dec 30, 2009 23:37:34 GMT 1
Niz, chain adjusters £34 inc postage cheers Graham
Post by guiri on Dec 31, 2009 0:22:35 GMT 1
them adjusters are well bling mate,pity i got nowhere to put some ..lol.
Post by sharpyg on Dec 31, 2009 0:39:55 GMT 1
them adjusters are well bling mate,pity i got nowhere to put some ..lol. well, I have got 1 or 2 RGV swing arms for sale if you need one
Post by sharpyg on Dec 31, 2009 1:20:24 GMT 1
Hi Do you have a pic of the N clocks and an idea of price? Cheers Rich Rich here are pics of the newly rebuilt (10 mins ago) clocks let me know if you are still interested please ? thanks Graham
Post by guiri on Dec 31, 2009 2:35:04 GMT 1
them adjusters are well bling mate,pity i got nowhere to put some ..lol. well, I have got 1 or 2 RGV swing arms for sale if you need one postage to spains a bit high mate... but how much do you want for one,i could send it to my sisters in cov and pick it up at a later date.post a piccy if you can. cheers and happy new year. john
Post by yoshi1157 on Dec 31, 2009 10:58:40 GMT 1
Yes I'm interested. PM sent
Post by yoshi1157 on Dec 31, 2009 11:00:40 GMT 1
Is the rev counter mechanical or electronic?
Niz
Post by Niz on Dec 31, 2009 17:54:48 GMT 1
Niz, chain adjusters £34 inc postage cheers Graham Ok thanks for the update Graham, you have PM !!!!! ;D
Post by sharpyg on Jan 1, 2010 0:45:57 GMT 1
Is the rev counter mechanical or electronic? electronic I believe on ypvs ?
Niz
Post by Niz on Jan 2, 2010 11:04:57 GMT 1
Niz, chain adjusters £34 inc postage cheers Graham Do you have a pay/pal account ? If so can you give me the details so i can send you the money. Thanks Neil
Post by sharpyg on Jan 2, 2010 11:36:01 GMT 1
Niz, chain adjusters £34 inc postage cheers Graham Do you have a pay/pal account ? If so can you give me the details so i can send you the money. Thanks Neil will pm you mate ta Graham
Niz
Post by Niz on Jan 3, 2010 13:56:51 GMT 1
Do you have a pay/pal account ? If so can you give me the details so i can send you the money. Thanks Neil will pm you mate ta Graham Ok no probs Graham , have sent you the money via pay/pal cheers Neil.
Post by sharpyg on Jan 3, 2010 14:52:01 GMT 1
Got it mate. Have ordered them, should be next week. Didn't I get a set of RGV forks from you ?
Niz
Post by Niz on Jan 3, 2010 15:04:23 GMT 1
Got it mate. Have ordered them, should be next week. Didn't I get a set of RGV forks from you ? yes hope so, your refurbishing them for me. ;D
Post by sharpyg on Jan 3, 2010 15:08:01 GMT 1
Hahaha ! Look good don't they
