Post by Tobyjugs on Dec 5, 2021 0:14:20 GMT 1
I like the swing arm
Post by abar121 on Dec 5, 2021 19:15:58 GMT 1
Just brilliant, as always.
Post by JonW on Dec 6, 2021 1:00:13 GMT 1
Looks great, nice work as ever!
Post by sidney81 on Dec 29, 2021 17:58:44 GMT 1
Hi everyone,had few jobs to do today on the bikes ,I went into work to use the lathe ,my brother's forks are fzr 400 and are to long ,so we had a work out and I've cut 25 mm off them ,this bringing them closer to stock ! Then re cut the thread's internally . I've not used the screw cutting gear on the lathe's before so I called in my good friend Phill ,he's been a precision engineer all his life , although he's now a office bod πhe's still very clever . I met him at the workshop this morning he brought some bits we didn't have mainly the cutting tip for 1 mm threads ,the thread is M30 X 1.0 mm pitch thread .so we got set up and he did his thing with me over his shoulder! So today I've learned how to screw cut ,old school πI've been wanting to do it for age's ,it's something we don't really have to do at work ,so thanks Phil , another job off the list for bro ! Thanks
Post by Mr Kipling on Dec 29, 2021 18:14:41 GMT 1
Top job,,,,
Post by wallcraft on Dec 29, 2021 20:50:31 GMT 1
Craftsman at work, say no moreπ
Post by midlifecrisisrd on Dec 29, 2021 20:58:25 GMT 1
Nice π
Post by oldbritguy on Dec 29, 2021 23:09:47 GMT 1
In todayβs world of CNC engineering, it is great seeing good old school work being done and to a great standard too. Fine skills there. π
Post by sidney81 on Dec 30, 2021 8:16:02 GMT 1
In todayβs world of CNC engineering, it is great seeing good old school work being done and to a great standard too. Fine skills there. π I totally agree ,my mate Phill ,I met him when I got my first job at 16 ,think he was 28 at the time ,I was in the fabrication side he was machine shop , and then he used to make awesome things for off shore / driving equipment all on the manual lathe's / mills really intricate stuff it use to fascinate me ,and he's very anal π€£,we have been friends ever since ! I'm now 40
Post by sidney81 on Dec 30, 2021 9:37:29 GMT 1
Post by sidney81 on Jan 8, 2022 19:31:15 GMT 1
Post by andy748 on Jan 8, 2022 20:39:29 GMT 1
I love looking at Chris's welds against the original Yamaha ones, pigeons everywhere! Andy.
Post by sidney81 on Jan 8, 2022 21:09:43 GMT 1
I love looking at Chris's welds against the original Yamaha ones, pigeons everywhere! Andy. ha ha funny you should say that ! Looking at my LC frame the welding is rubbish ,full of spatter ,even bit of mig wire poking out on the rad mount, when I strip it for powder coating I'm going to go over it all .
Post by JonW on Jan 11, 2022 0:37:12 GMT 1
Too funny, I spent a bit of time trying to recreate the Yam poor welding when I did my framework so it looked original in case any tester here wanted to say my frame had been er, 'modded'... not all mate! lol Im not the best welder at all, but wow the OEM stuff was terrible if i had to struggle to recreate it lol
Post by shawski46 on Jan 11, 2022 21:38:08 GMT 1
Iβm new here lots of useful info on here
Post by sidney81 on Jan 15, 2022 18:03:52 GMT 1
Hi everyone , I've made a new gear leaver for the pv ,the original was shagged and bent ! I brought a linkage kit off the bay ,2 ball joints and the threaded rod with lh and rh thread . I cut the new lever from 6 mm st st ,I cut a nice curved shape like stock ! ,I machined up a st st bush for the pin ,and machined up the toe part , this is puddle welded in the back so you can't see the weld . I welded the pin bush in with my Tig ! The finish is brushed , it looks really nice better thank the stock steel one for sure!! The gear leaver sits on a pin and c clip holds it on !! The pin was shagged to so I've machined up a new pin to go with the new bush ! This time I've drilled n taped the end m6 so it's held on with a nice dome head with a washer ,better than a c clip imo !! I've got a new st st bolt and welded the new pin to it ,and machined a groove in for the greese ! It's tight as a drum no play at all and looks trick (I think) ππ
Post by dusty350 on Jan 15, 2022 18:12:24 GMT 1
Awesome work Chris, as always
Post by andy748 on Jan 15, 2022 18:22:45 GMT 1
The only issue i see with this Chris is we can't bloody have one! Brilliant work. Andy.
Post by sidney81 on Jan 15, 2022 18:43:15 GMT 1
Thanks chaps I'm glad you like it ,I really enjoyed making it ,and it's not on my bike π£π
Post by panzermatt on Jan 15, 2022 19:23:22 GMT 1
jesus thats class Git, really nice work.
Post by abar121 on Jan 15, 2022 20:11:14 GMT 1
Just stunning. Love the machine and welding work. Great photos to make us all envious too
Post by mouse on Jan 15, 2022 22:12:18 GMT 1
Absolutely outstanding!
So, can we add rearsets to the list of things you could potentially make/sell??
I know these are based on standard footrests etc but if you can do that...And there are few options for LC/YPVS rearsets!
Mouse
Post by sidney81 on Jan 16, 2022 0:13:44 GMT 1
Thanks for the nice comments!! Means alot , yes I suppose I could make some π
Post by yamark on Jan 16, 2022 18:25:40 GMT 1
A joy to look at your work Chris Top draw as always
Post by sidney81 on Jan 16, 2022 20:47:07 GMT 1
A joy to look at your work Chris Top draw as always thank you Mark ! As is yours and some π
Post by sidney81 on Jan 26, 2022 21:43:07 GMT 1
Hi everyone ! Just a little update! I received the pipes today from Martin Johnson ,I'm going with his pipes again because I I know what I'm up to with them ,my brother likes them to ,he has a set on his tzr . They came in kit form so I'm going to fab and weld them up myself as I did on my LC , tommrow night brother is over so we can crack on with them π
Post by evochris on Jan 26, 2022 21:57:59 GMT 1
Nice pipes, look forward to seeing these put together, good luck with the build
Post by sidney81 on Jan 26, 2022 22:00:58 GMT 1
Nice pipes, look forward to seeing these put together, good luck with the build thank you! I will update the progress π
Post by dusty350 on Jan 26, 2022 22:02:22 GMT 1
Looking forward to the pipes taking shape Dusty
Post by oldbritguy on Jan 27, 2022 7:35:13 GMT 1
Chris. Can I hang about your workshop just to make tea and learn stuff? This thread is an education on its own. Superb buddy and keep the pics coming. John
