Post by midlifecrisisrd on Nov 10, 2020 18:04:30 GMT 1
Oh dear
That's had all the mounts broken and been splattered with P40
Post by pedheadfred on Nov 10, 2020 18:13:59 GMT 1
Fibreglass matting and resin aswell weighs a ton propper bodge job
Post by JonW on Nov 10, 2020 23:07:51 GMT 1
Nasty. I'll never understand why people think the way to 'repair' plastic is with fibreglass. what is the thought process behind that?!
Good news is that you can still find better ones of these and you can save this nasty one as a bit of garage art.
Post by midlifecrisisrd on Nov 12, 2020 16:00:44 GMT 1
Fibreglass matting and resin aswell weighs a ton propper bodge job Oh FFS boyo, check yer thread on the 2 stroke forum I've found you a top fairing. Hurry up before some other Bugger snaffles it 😉 Steve
Post by pedheadfred on Mar 30, 2021 21:46:35 GMT 1
Right folks been a while I've now got a replacement top Fairing that had a couple of damaged bits but I've plastic welded broken missing bits from a mates smashed fairing. And another steel headlight bracket with all its little tangs and brackets intact , Only thing is the top of the bracket I think it's were mirrors fasten on to. It has been ground away had it got captive nuts inside for mirrors to fasten to ? If yes what size thread are they supposed to be ? As orginal ones knackered
Post by pedheadfred on Mar 31, 2021 18:01:19 GMT 1
The s the bracket Original had this on it aswell what fastens in the holes
Post by midlifecrisisrd on Mar 31, 2021 18:16:28 GMT 1
Sorry but can't help you ☹
I've never had a faired bike
Post by pedheadfred on Mar 31, 2021 20:06:07 GMT 1
Sorry but can't help you ☹ I've never had a faired bike Steve Thanks for at least taking part 😜
Post by abar121 on Mar 31, 2021 20:31:06 GMT 1
Post by pedheadfred on Mar 31, 2021 20:55:03 GMT 1
Thanks just exactly what i Needed it's mirror bracket looks to be m8 aswell. 👍😉 Many thanks for your help
Post by JonW on Apr 1, 2021 0:46:00 GMT 1
yes M8 threads, the other smaller one (dash?) is M6.
Post by pedheadfred on Apr 8, 2021 23:58:14 GMT 1
Thanks everybody for above help 😜👍, another question is my right side switch throttle body is missing it's internals. And as it has what appears to be a twin cable setup but another bodger up cable been used I thought about using another unit and modify the cable end that fits the carbs as this Rz has linked carbs single cable working them. The loom I've got has a rectangle plug for the switch loom connection. So what model bikes switch gear has this connector fitted ? As I think finding a correct cable will be a pain and I still need the switch gear internals to make it function aswell
Post by JonW on Apr 9, 2021 0:43:32 GMT 1
I think we are going to need photos of the stuff youre talking about here to help you identify this.
Post by pedheadfred on Apr 9, 2021 8:30:45 GMT 1
Post by midlifecrisisrd on Apr 9, 2021 8:54:30 GMT 1
I'm a bit confused with the wiring plug
Usually a RH switch has 5 wires, that plug has 6 so I'm wondering what it is for 🤔
I'd have to check the wiring diagram
Also, does your RH switch body have 1 or 2 holes for throttle cables
The ones with 2 are rare as UK or Europe never had the 2 Cable system
I may have the correct 2 cable throttle Cable but no use if your housing only has one or you can't get internals for yours
Post by abar121 on Apr 9, 2021 10:32:30 GMT 1
I may also have a 2 hole hosing and one of the cables for the linked carbs.
I've just put stock 31k separate carbs on my US RZ.
Post by pedheadfred on Apr 9, 2021 15:18:16 GMT 1
This is the loom my mate gave me for the bike but was bought off eBay didn't come with the bike
Post by pedheadfred on Apr 9, 2021 15:28:59 GMT 1
Post by midlifecrisisrd on Apr 9, 2021 15:56:20 GMT 1
No pics mate
Post by pedheadfred on Apr 9, 2021 20:07:57 GMT 1
This is the loom my mate gave me for the bike but was bought off eBay didn't come with the bike Are they here now as I can see them
Post by abar121 on Apr 9, 2021 20:15:02 GMT 1
Yep, can see them now.
Post by pedheadfred on Apr 9, 2021 20:28:24 GMT 1
Good thought I Was seeing things 😵👍
Post by JonW on Apr 10, 2021 1:38:23 GMT 1
51L loom... hmm... most F1s are a 57V loom, so that sounds like a JDM loom perhaps and that dovetails with the 2 cable throttle (USA parts from partzilla etc will work there) and Im not 100% sure what differences they had.... certainly an 80kmh light on the dash, but that shouldnt be in the loom it will be in the dash? hmm... Anyway, 51L is defo an 84/5 and an F1 so thats very close, i doubt you'll get closer to be honest these days.
Re the switch, I think you should just find an 85 switch and go from there with tracing the wires and working it out. the 83/4 is the same but has shorter wires and diff connectors as they connect in the headlight, on the 85 its under the infill panel/tank.
I do remember a connector like that on my F1 i think... Anyway, this is going to take some time to work out i think. Diff markets had diff things on the switches, ie some had lights on/of, some had parker setting, some had no switch as lights were always on. Its all about rules for each market. Same as on other side some have 'pass' some dont (like Canada). If you have a loom from a market with something extra/missing you will have diff amounts of wires in the blocks. Same with the switches, some have less/more wires coming from them. They can also be diff colours as the switch is generic for that market and is used on other bikes, the look would have been made to cope with that etc.
Also some markets didnt have indicator timer and that is deleted in diff ways.
It is possible with time and effort to work this out and make it all work, I love that kind of challenge, but know its not everyones cup of char.
cnkxu1
Post by cnkxu1 on Apr 10, 2021 4:42:33 GMT 1
Post by abar121 on Apr 10, 2021 8:53:36 GMT 1
It's the same crankcase.
Post by pedheadfred on Apr 10, 2021 12:04:14 GMT 1
Yes my bike hes asked me if he could use on his site as reference
Post by pedheadfred on Apr 10, 2021 12:06:51 GMT 1
Yes it's my crankcase he asked my permission to use it on his site as a reference as it's according to his knowledge a Venezuelan Rz250rr model made for one year in that Country.Second pic was close up I sent him by private message
Post by pedheadfred on Apr 11, 2021 14:02:39 GMT 1
Found a switch on eBay so bought it Just need to buy a UK cable now then remove the twin cables for carbs and source a cable for the cab linkage. Allso got pair new mirrors and a front brake master cylinder so slowly collecting parts for this never up bike.
Post by pedheadfred on Apr 11, 2021 22:41:53 GMT 1
Just realised front mudguard not right one aswell anywhere sel copy ones ? Or good fibreglass copies. Or anybody got one kicking about?
Post by pedheadfred on Apr 15, 2021 16:52:04 GMT 1
Found a switch on eBay it's arrived today and everything matched up on loom Inc colours on wires.
