Rgv Ypvs
Aug 17, 2020 7:34:33 GMT 1
via mobile
JonW likes this
Post by botty on Aug 17, 2020 7:34:33 GMT 1
What are the forks off? I assume a Honda? Honda wheel with Rc 30 discs Triumph takes 320mm discs Triumph Daytona/ Speed Triple forks
Rgv Ypvs
Aug 30, 2020 21:46:42 GMT 1
via mobile
Post by botty on Aug 30, 2020 21:46:42 GMT 1
That rolling chassis looks perfect. Thanks pal. Need to get going on it again
Post by botty on Aug 30, 2020 21:48:09 GMT 1
Domes machined for long stroke crank
Post by flames on Aug 30, 2020 22:34:20 GMT 1
Looks amazing......shame you can't fit them upside down and have on show.
Post by Tobyjugs on Aug 30, 2020 23:48:50 GMT 1
The domes look good. How much bigger are they compared to your piston diameter. I noticed on my Drive Line cylinder head that there is a bit of movement in the fitment of the head and it can be fitted a tiny bit c**keyed which meant the piston crown could hit the dome.
Rgv Ypvs
Aug 31, 2020 1:21:30 GMT 1
via mobile
Post by botty on Aug 31, 2020 1:21:30 GMT 1
The domes look good. How much bigger are they compared to your piston diameter. I noticed on my Drive Line cylinder head that there is a bit of movement in the fitment of the head and it can be fitted a tiny bit c**keyed which meant the piston crown could hit the dome. Will have a measure and get back. I didnโt machine them
Post by botty on Aug 31, 2020 1:25:29 GMT 1
Oversight on the dry build. No header tank catered for. Luckily found one in my โ cannot throw that outโ shite stash. Plus a place to mount it
Post by jon on Aug 31, 2020 11:15:36 GMT 1
The domes look good. How much bigger are they compared to your piston diameter. I noticed on my Drive Line cylinder head that there is a bit of movement in the fitment of the head and it can be fitted a tiny bit c**keyed which meant the piston crown could hit the dome. Itโs like buses, when two come along at once. Only yesterday was I thinking about this. One solution was to pin the head. I have fresh 65mm bores on a YPVS. I was thinking of turning up 2 x10mm thick disks. Then a rod to snugly fit in the spark plug threads attached to the disks. Drill a hole in the head and insert a pin just protruding but with a sharp point put the disks in the barrels, bolt the head up and hopefully centre punch the barrel. That way it should be square and need minimal over the 65mm. Was thinking of 66mm. Jon
Rgv Ypvs
Aug 31, 2020 11:35:02 GMT 1
via mobile
Post by midlifecrisisrd on Aug 31, 2020 11:35:02 GMT 1
The domes look good. How much bigger are they compared to your piston diameter. I noticed on my Drive Line cylinder head that there is a bit of movement in the fitment of the head and it can be fitted a tiny bit c**keyed which meant the piston crown could hit the dome. Itโs like buses, when two come along at once. Only yesterday was I thinking about this. One solution was to pin the head. I have fresh 65mm bores on a YPVS. I was thinking of turning up 2 x10mm thick disks. Then a rod to snugly fit in the spark plug threads attached to the disks. Drill a hole in the head and insert a pin just protruding but with a sharp point put the disks in the barrels, bolt the head up and hopefully centre punch the barrel. That way it should be square and need minimal over the 65mm. Was thinking of 66mm. Jon Check the head bolts in the head for slack Know when slinger did my head it is matched to the bore size (as in if I bore out to next size I need the head cut again) but it is not pinned Discovered the head bolt holes are tapered on the head when I had to grind down my SS head bolts as a few got tight before they gripped the head Looked like some holes were made tighter to locate the head in place May just have been a one off but worth checking Steve
Rgv Ypvs
Aug 31, 2020 23:38:04 GMT 1
via mobile
Post by botty on Aug 31, 2020 23:38:04 GMT 1
The domes look good. How much bigger are they compared to your piston diameter. I noticed on my Drive Line cylinder head that there is a bit of movement in the fitment of the head and it can be fitted a tiny bit c**keyed which meant the piston crown could hit the dome. Pistons are 64.5 Domes are 65.8 Will take note of what you are saying ๐
Post by botty on Nov 29, 2020 23:25:00 GMT 1
Got a bit more done. Iโm using a Driveline clutch pressure plate kit. Thought I had best address the other issue. โSaggy Rubbersโ Out with the old In with the new Waiting for the EBC plates to arrive, couldnโt wait to see how the painted cases looked
Post by JonW on Nov 30, 2020 0:45:06 GMT 1
That grey looks superb. Very 90s Yam.
2taol
Post by 2taol on Nov 30, 2020 8:38:31 GMT 1
beautiful engine, love the gray and polished alu.
Rgv Ypvs
Nov 30, 2020 17:52:22 GMT 1
via mobile
Post by ypvsimon on Nov 30, 2020 17:52:22 GMT 1
Great project.. it's going to be a beast!!
Rgv Ypvs
Nov 30, 2020 18:45:03 GMT 1
via mobile
Post by Tobyjugs on Nov 30, 2020 18:45:03 GMT 1
That's the first time I've seen engine casings I can get enthusiastic over.
Nice choice.
Rgv Ypvs
Nov 30, 2020 19:19:03 GMT 1
via mobile
Post by botty on Nov 30, 2020 19:19:03 GMT 1
That grey looks superb. Very 90s Yam. I think it looks ๐๐
Rgv Ypvs
Nov 30, 2020 19:19:26 GMT 1
via mobile
Post by botty on Nov 30, 2020 19:19:26 GMT 1
beautiful engine, love the gray and polished alu. Thank you ๐
Rgv Ypvs
Nov 30, 2020 19:20:10 GMT 1
via mobile
Post by botty on Nov 30, 2020 19:20:10 GMT 1
Great project.. it's going to be a beast!! I hope so. Looking forward to fitting the engine now.
Post by botty on Nov 30, 2020 19:20:45 GMT 1
That's the first time I've seen engine casings I can get enthusiastic over. Nice choice. Thanks pal. Really pleased how they came out..
avb
andys vapour blasting
Post by avb on Nov 30, 2020 20:14:33 GMT 1
hi tony looking well is that the engine i vapour blasted for you
Rgv Ypvs
Nov 30, 2020 20:28:19 GMT 1
via mobile
Post by botty on Nov 30, 2020 20:28:19 GMT 1
hi tony looking well is that the engine i vapour blasted for you It is Andy. Looks bang on. Cheers pal ๐
Post by botty on Dec 4, 2020 0:04:20 GMT 1
Iโve had some clutch slip issues with my Tdr385. Same spec as this motor. However it runs fully synthetic gear oil. Which might be the cause. So to rectify the issue with this motor. Iโm going back to Motul mineral oil. Heard lots of positive comments about the Driveline pressure plate. So using one of them. So hoping this clutch doesnโt slip.
Rgv Ypvs
Dec 4, 2020 5:38:38 GMT 1
via mobile
Post by Tobyjugs on Dec 4, 2020 5:38:38 GMT 1
I put one in a 4LO for sprinting and it worked a treat. Without the stealth locker the oil was black. The next time with the stealth locker the oil was still clean so did it's job well.
Post by botty on Dec 4, 2020 18:58:27 GMT 1
I put one in a 4LO for sprinting and it worked a treat. Without the stealth locker the oil was black. The next time with the stealth locker the oil was still clean so did it's job well. Thatโs good to hear. Another satisfied Stealth user.
Post by 4l04ever on Dec 4, 2020 19:05:25 GMT 1
The stealth locker looks good, unless you get your balls jammed...
Rgv Ypvs
Dec 5, 2020 10:18:33 GMT 1
via mobile
Post by botty on Dec 5, 2020 10:18:33 GMT 1
The stealth locker looks good, unless you get your balls jammed... Is that a joke Rob, or a serious warning ๐ฌ๐ฌ?
Post by 4l04ever on Dec 5, 2020 14:35:34 GMT 1
The stealth locker looks good, unless you get your balls jammed... Is that a joke Rob, or a serious warning ๐ฌ๐ฌ? Possibly both! In theory, the balls could jam of the aluminium backing plate wears as the balls get crushed. Would be worth checking after it has been in for a while.
Post by 4l04ever on Dec 5, 2020 14:37:48 GMT 1
Also, if these work as well as the other style of lockup clutch, you should not need any heavy springs, as it looks like you have 3 of one type and 3 of another??
Rgv Ypvs
Dec 6, 2020 1:11:03 GMT 1
via mobile
Post by botty on Dec 6, 2020 1:11:03 GMT 1
Is that a joke Rob, or a serious warning ๐ฌ๐ฌ? Possibly both! In theory, the balls could jam of the aluminium backing plate wears as the balls get crushed. Would be worth checking after it has been in for a while. The backing plate is steel Rob. So should be ok.
Rgv Ypvs
Dec 6, 2020 1:12:23 GMT 1
via mobile
Post by botty on Dec 6, 2020 1:12:23 GMT 1
Also, if these work as well as the other style of lockup clutch, you should not need any heavy springs, as it looks like you have 3 of one type and 3 of another?? I thought the same thing after I took the picture. So put the other three standard oneโs back in before I locked it down ๐
