Post by boomflamingo on Jan 19, 2020 15:41:28 GMT 1
Hi when starting my 350lc for the first time yesterday, occasionally the kick start would jam and had to put the bike into gear and rock back and forth to free it. i also noticed a noise from the kick start area when bike was running. i have pulled off the clutch cover and cannot see anything obvious other than quite a lot of play with one of the gears. I am not sure if this is normal, so would like advise please. i will try and upload a video to show Thanks
Post by alankelly on Jan 19, 2020 16:01:56 GMT 1
Hi
Yes the bush on this gear tends to wear that then makes it a sloppy fit on the shaft
In really bad cases the gear can catch on the side of the clutch basket primary gear
If you message 4L04EVER he can re bush it for you to restore it to the correct original fit
Best wishes Al
Post by stusco on Jan 19, 2020 16:21:48 GMT 1
Norbo used to sell the idle gear He still does £61 genuine
Post by Tobyjugs on Jan 19, 2020 17:14:51 GMT 1
Check to see if it is shimmed correctly as well
Post by boomflamingo on Jan 19, 2020 18:06:14 GMT 1
So that much play is not normal then?
Post by oldelsieboy on Jan 19, 2020 18:09:55 GMT 1
So that much play is not normal then? Normal, yes Correct, no OEB
