Post by simon998 on Jan 13, 2020 11:32:46 GMT 1
I picked up a TZR left hand switchgear from Norbo a while ago, it stated that the wiring was slightly different to the RD 125 LC. I've temporarily wired up the switch gear to the loom with bullet connectors and can get everything working apart from the indicators. I've two wires left, and a double earth on the loom and two wires coming from the switch gear. Then there's a random 4 pole plug which has nothing to connect to. Any ideas? Thanks
Post by simon998 on Jan 17, 2020 23:27:19 GMT 1
Anyone? Heading back up to this tomorrow and it's one of the last things i need to sort
Post by tacky1 on Jan 17, 2020 23:44:59 GMT 1
You would have to open up the switch and see where they are going to, Does the TZR have a Headlight flash button, You know the one on the front of the switch,,,, Might be it
Post by JonW on Jan 18, 2020 12:44:42 GMT 1
Find the wiring diagrams for both bikes and check the switch info on there as they show the connections on them as well as the wiring and write them down for each and you should be able to sort this. I doubt many people here have experience of TZR switches...
I actually assumed you had used the wiring diagrams to work out what you had so far, if that is not the case then you should start again as you can never just assume with this stuff :/
Post by midlifecrisisrd on Jan 18, 2020 13:43:31 GMT 1
As jonw said you need diagrams
About to do it with f2 switchgear onto 31k loom
Post by stusco on Jan 18, 2020 14:24:03 GMT 1
Post by simon998 on Feb 11, 2020 13:18:20 GMT 1
That's the RD one at the top, TZR 2HK at the bottom (What my switch gear is off) The switches are physically identical (Norbo sells them in the RD 125 LC section as replacements), only the connecting plug was different to my RD loom.
Post by simon998 on Feb 11, 2020 13:20:17 GMT 1
I don't see this connector on the RD wiring diagram anywhere, could this be the indicators?
Post by Jethro5 on Feb 11, 2020 22:49:45 GMT 1
If you compare the wire colours on 4 pole plug to the 125 wiring diagram it would appear that plug is the indicators.
Post by simon998 on Mar 6, 2020 13:05:49 GMT 1
Yes, ~I meant to say, I have since sorted this and that white block is indeed the indicators, well, 3 of the cables are. I'm just struggling to get the sidelight wired in now and the job's a goodun
