Post by baz69 on Jan 11, 2020 22:02:02 GMT 1
Got new bushes for tie bars ,have mislaid bolts ,the ones that go under tie bars into casing ,can someone confirm length please,don't want to risk busting up into cases ,also torque measures in newton metres if poss. Thanks
Post by ianboom on Jan 11, 2020 22:09:57 GMT 1
Ypvs in M10 x 40 LC I thought was M10 x 35, but the parts manual says 55mm?! 28 lbsft or 38nm according to Haynes!
Post by baz69 on Jan 11, 2020 22:16:14 GMT 1
Top man ,cheers
Post by markhoopy on Jan 11, 2020 23:57:44 GMT 1
Post by ianboom on Jan 12, 2020 8:38:53 GMT 1
Post by jon on Jan 12, 2020 10:41:02 GMT 1
Just my two pennith worth, but I rarely look up the size of a bolt.
Measuring everything is IMO a much better way.
Take a suitable M10x1.25 bolt screw it into each hole in the case by hand until it just bottoms out. Measure the protruding bit and take it away from overall length.
Then measure tie bar bush thickness and any flat and spring washers your likely to use and work out the length needed (taking a mm or so off).
I do this to get maximum engagement and therefore strength with any bolt hole. This helps to stop threads being pulled in aluminium through frequent use or overtightening.
I must admit I have the luxury of a lathe and often turn bolts down to any length, not just multiples of 5mm.
