Post by pdxjim on Dec 30, 2019 4:46:14 GMT 1
What, if any, sealant to use on the water pump gasket?
Post by JonW on Dec 30, 2019 7:13:12 GMT 1
i never used to seal them but i always do now after my resto LC leaked like a sieve even with cleaned and faced replated cover, new gasket and cleaned up case. In the end I refaced the case and sealed it with 1194 and used bolts, not the OEM screws. Not a drop has dripped since.
Post by dusty350 on Dec 30, 2019 8:02:17 GMT 1
I use 1104 or 1194 too. So many gasket faces on these old engines show marks and gouges from previous strip downs, so a bit of 3bond gives your gaskets an easier time. Dusty
Post by midlifecrisisrd on Dec 30, 2019 9:59:29 GMT 1
If a genuine gasket (it has a sealant ridge on it) and both faces good I fit dry
If pattern or any pitting I use clear silicone (I get Fernox free from work 😏)
Post by jon on Dec 30, 2019 10:18:47 GMT 1
As Steve says, if genuine then dry.
However if using a paper gasket I smear it with a thin layer of grease. I don’t like the idea of sealant squashed out and entering the coolant system.
Post by 4l04ever on Dec 30, 2019 14:02:30 GMT 1
A smear of grease also helps when you come to remove the gasket. I do this on base gaskets and the clutch cover gasket too. I use Threebond on the reed block gaskets as they are the most like place for an air leak.
Post by jon on Dec 31, 2019 10:46:25 GMT 1
A smear of grease also helps when you come to remove the gasket. I do this on base gaskets and the clutch cover gasket too. I use Threebond on the reed block gaskets as they are the most like place for an air leak. Hi Rob, I did 100% what you mention above with a dry genuine head gasket. Used you gaskets and no leaks at all on my latest YPVS. Jon
