Lc2 carbs
Dec 29, 2019 11:20:15 GMT 1
via mobile
Post by Dixie Dean on Dec 29, 2019 11:20:15 GMT 1
Hi everybody I have a problem with my standard carbs on my lc2.Using a aux tank when I first turn on the tap the left hand carb overflows from both overflow but when I start the engine it stops anybody help thanks.
Lc2 carbs
Dec 29, 2019 15:14:10 GMT 1
via mobile
Post by midlifecrisisrd on Dec 29, 2019 15:14:10 GMT 1
Float level/needle valves
Have you fitted new seats/valves?
Lc2 carbs
Dec 29, 2019 16:12:05 GMT 1
via mobile
Post by Dixie Dean on Dec 29, 2019 16:12:05 GMT 1
Fitted new float valves will have to try new needle valves thanks
Post by Tobyjugs on Dec 29, 2019 16:26:36 GMT 1
Fitted new float valves will have to try new needle valves thanks This sounds confusing what do people mean by needle valves???
Lc2 carbs
Dec 29, 2019 17:31:08 GMT 1
via mobile
Post by midlifecrisisrd on Dec 29, 2019 17:31:08 GMT 1
To me the needle valve is the valve the floats operate
The ones with the rubber tips
Suppose it's just called the float valve
The seat is the brass bit it goes into with the o ring around it
