Post by chrisg on Dec 23, 2019 23:42:53 GMT 1
Hi, I notice that the indicator flasher relays available for the LC1 has 2 pins, whereas my relay has 3 pins. Is this a replacement and will the auto cancel function still work or is the auto-cancel a different unit.? Electrics not my best subject Thanks
Post by midlifecrisisrd on Dec 24, 2019 9:59:29 GMT 1
You need a 3 pin for self cancelling
Post by oldelsieboy on Dec 24, 2019 10:01:21 GMT 1
You need a 3 pin for self cancelling Steve And, AFAIK, it has to be an OEM relay (tried plenty of other 3 pin relays without success) OEB
Post by midlifecrisisrd on Dec 24, 2019 10:04:42 GMT 1
You need a 3 pin for self cancelling Steve And, AFAIK, it has to be an OEM relay (tried plenty of other 3 pin relays without success) OEB Correct sir I've never messed with the pin orientation so can't comment on it being made to work I've just took the easy option and spent a fiver on a good used relay Steve
