Post by skydemon on Dec 21, 2019 23:14:32 GMT 1
Evening chaps. Want to bore out my DT125 LC so need a new barrel and head. Basically will a 10W barrell work?? It’s a Mk1 10V French import. MTIA. P
Post by cinder on Dec 26, 2019 10:29:58 GMT 1
Yes it will work fine.there is a slight difference in port timing but at worst it will rev harder
Post by shell2tx on Dec 29, 2019 14:21:35 GMT 1
Yes will fit straight on but you will have to jet up to rd spec and you will loose all bottom end power, could never understand why nobody put a dt 10v topend on an rd back in the day as i was getting 87mph out of a 10v std bike with rd 16t front spkt back in the day and you were dancing on the gearbox all day with an rd 125lc to keep a decent speed ,i have 3 black 3 blue and 2 white 10v/12w,s up here, incedently i also put a 17t front sprkt from an rd125lc on the front of my kmx200 back in the late 80s as nobody did one for the kmx at the time fitted straight on and would pull 100mph sitting up, highly recommended bikes just need a better front brake as do 10v,s i swear mine used to speed up when i put the front brake on !
Post by skydemon on Dec 30, 2019 19:54:59 GMT 1
Was using it for a 10V DT12 5LC175 blaster piston conversion I’ll need a 28 min mikuni carburettor. Some oil pump adjustment and a good old Rolling Road. Do you think I would be better off with a 10V barrel then? Many thanks in advance. Pete
