craigo
Post by craigo on Dec 21, 2019 23:07:19 GMT 1
Me again. Haynes shows a hex nut ( cap ) to unscrew from top of fork leg that has the air valve on it . Mine has an air valve fixed to a flat plate with no means of unscrewing it . How does this come out from the top of fork leg ? Thanks
Post by cb250g5 on Dec 21, 2019 23:20:49 GMT 1
push down. remove circlip.
Sounds easy, but is actually often a real pain without an extra pair of hands..
craigo
Post by craigo on Dec 21, 2019 23:38:29 GMT 1
Great thanks. Iβll try that π
Post by JonW on Dec 21, 2019 23:41:34 GMT 1
use the patented JonW dodge from my 251LC thread (bottom of page 1 for full info)
Post by paulincayman on Dec 21, 2019 23:50:30 GMT 1
Like that!!
craigo
Post by craigo on Dec 22, 2019 0:05:45 GMT 1
Brilliant.... itβs out . Thanks
Post by JonW on Dec 22, 2019 0:21:22 GMT 1
Haha, glad it worked. I wish I had actually patented it I might one day get rich lol The beauty is that the socket protects the shrader valve from damage and if you chose the right one from your set you can easily get the clip out.
Post by Shytalk on Dec 22, 2019 10:41:06 GMT 1
use the patented JonW dodge from my 251LC thread (bottom of page 1 for full info) Ooh, I like the thinking there, easy when you think about it and using no special tools either πππ
Post by cb250g5 on Dec 22, 2019 12:10:46 GMT 1
If only I had handlebar clamps....
Post by JonW on Dec 22, 2019 12:47:02 GMT 1
If only I had handlebar clamps.... Yes not perfect for the 85 on models, but defo good for earlier. You could use a spare early ypvs top triple when the forks are off the bike to do this tho, the early tops fit the later forks etc
Post by cb250g5 on Dec 22, 2019 15:24:23 GMT 1
FZR 250 Yokes. I managed with the use of my woodworking vice and a small clamp.
