Post by andrel on Dec 17, 2019 19:11:33 GMT 1
Sorry if a stupid or obvious question, but i no longer have the standard plugs and need to make the alternator to rectifier wiring connection manually.
The 3 thick white wires comming from the alternator - do they connect with the three corresponding white wires coming from the rectifier in any order?
If not, how do i figure out which white alternator wire connects with its corresponding white rectifier wire?
Thanks
Post by dusty350 on Dec 17, 2019 19:21:19 GMT 1
Any white connects to any white Dusty
Post by andrel on Dec 17, 2019 19:33:36 GMT 1
Any white connects to any white Dusty Thanks Dusty, that is a relief to know. Do not want to burn out my bike at the tail end of the build While you are here and if i may draw on your knowledge - how do one know whether the alternator sits far enough back on the crank? The nut is flush with the end of the shaft (maybe a turn or two in), torqued to spec, the raised bit runs directly underneath the pick-up and nothing makes contact with the plastic cover, but if you look at the back of the alternator a few mm of the windings can be seen sticking out. Not sure my description makes sense. Will try and post a picture.
Post by dusty350 on Dec 17, 2019 20:02:24 GMT 1
Hi Sounds about right. Don't forget the rotor needs to clear the stator plate mounting bolts. I draw a line across the rotor nut once it's torqued. That way it's easy to see if the nut ever loosens off; 44612903800_63ca857e42_k[1] by dusty miller, on Flickr Dusty
Post by andrel on Dec 17, 2019 21:26:54 GMT 1
Thanks Dusty. Good idea with the marking, think i will do the same. Cheers.
Post by andrel on Dec 18, 2019 17:29:36 GMT 1
Here is a pic - seems OK?
Post by dusty350 on Dec 18, 2019 18:41:34 GMT 1
Looks right to me As you say, the raised pick up on the rotor runs directly under the stator sensor, just where it needs to be, and you have clearance on the stator fixing bolts. Dusty
