Post by midlifecrisisrd on Dec 10, 2019 12:39:02 GMT 1
Morning peeps
Just out of interest what do you guys lube your crank seals with when fitting
Over the years I've done 2 stroke oil, engine oil, lm grease and that black cv stuff I can't pronounce or spell π
Post by JonW on Dec 10, 2019 12:43:56 GMT 1
2 stroke oil.
Post by markhoopy on Dec 10, 2019 12:51:22 GMT 1
+1 for two stroke oil just because you know it can't do any harm using it
Post by ianboom on Dec 10, 2019 12:53:10 GMT 1
Black stuff, do you mena molybdenum disulfide??
I use 2 stroke oil!
Post by midlifecrisisrd on Dec 10, 2019 13:27:11 GMT 1
Black stuff, do you mena molybdenum disulfide?? I use 2 stroke oil! That's the stuff Steve
Post by reedpete on Dec 10, 2019 13:33:20 GMT 1
I lube them with my finger π
Post by Tobyjugs on Dec 10, 2019 13:42:06 GMT 1
I use two stoke oil, but I have also used Parker Super Lube or Molykote 111 on other builds. For example. For my big bore engine I used Molykote 111 because I knew it would be a slow build.
Post by earthman on Dec 10, 2019 14:44:32 GMT 1
Black stuff, do you mena molybdenum disulfide?? I use 2 stroke oil! That stuff is called for when swapping out valve shims on my 4 stroke, well a 50/50 mix with engine oil. I dunno about using it against seals, would have thought that may not be a good idea??
Post by midlifecrisisrd on Dec 10, 2019 14:58:22 GMT 1
Black stuff, do you mena molybdenum disulfide?? I use 2 stroke oil! That stuff is called for when swapping out valve shims on my 4 stroke, well a 50/50 mix with engine oil. I dunno about using it against seals, would have thought that may not be a good idea?? Doesn't do the cv boots on your car or pv seals any harm π Steve
Post by bare on Dec 10, 2019 21:58:37 GMT 1
Engine assembly goo Red and viscous.. it doesn't drip off between applying and 'eventually' running
Post by risolc on Dec 10, 2019 22:27:06 GMT 1
Come on bare give us names, my build will particularly slow and am concerned 2 stroke oil will eventually drip off leaving it vulnerable when eventually started. 1st time builder and any advice greatly appreciated.
Post by 137d on Dec 10, 2019 22:45:07 GMT 1
Post by tacky1 on Dec 10, 2019 23:39:06 GMT 1
I use slick honey on all my seals, 2-Stroke oil is probably what I would use if I didn't have any SH
Post by bare on Dec 12, 2019 19:32:32 GMT 1
db8888
Post by db8888 on Dec 12, 2019 21:05:23 GMT 1
lithium soap based grease
Post by wallcraft on Dec 15, 2019 22:41:52 GMT 1
I'm in the porn industry and get sh*t loads of KY jelly, so use that usally π
Post by Tobyjugs on Dec 16, 2019 1:43:26 GMT 1
I'm in the porn industry and get sh*t loads of KY jelly, so use that usally π Ha Ha nice one. Sometimes that's what I think as well.
busby
RD 350 4l0
Post by busby on Dec 28, 2019 17:30:47 GMT 1
The good old Haynes manual says to pack the gap between the seal lips with grease, but does not go into any other detail. Not all that helpful but then itβs a Haynes manual πππππ
