Post by scooter on Nov 24, 2019 20:35:42 GMT 1
hi all im swaping my yokes for some modern ones the bearing sizes are the same but the stem is about a inch longer. my question or questions are if i simple use a 1 inch spacer below the bottom bearing would a 1 inch bolt be to long to act as lock stops ie to flexable or do i grind the weld off the bottom of the stem and push it through the bottom yoke a inch cut off the surplus and reweld it many thanks for now scooter
Post by dusty350 on Nov 24, 2019 21:27:14 GMT 1
Stem swap would be best. Cant you get the stem from the standard yokes and weld them into the new ones ? Would look and work much better that way. An inch long spacer under the bearing sounds excessive Dusty
yoke swap
Nov 24, 2019 22:03:28 GMT 1
via mobile
Post by midlifecrisisrd on Nov 24, 2019 22:03:28 GMT 1
Ive fitted fazer 600 yokes twice now which were 20mm or so longer
Got a machine shop to cut the bearing section and the threaded top 20mm further down the stem then cut 20mm off
Depends on the stem shape
Post by marrcel on Nov 24, 2019 22:11:24 GMT 1
Making a new stem is easier and cheaper.
Post by scooter on Nov 25, 2019 12:36:19 GMT 1
Hi all I don't think the original stem will work dusty 350 as the new top yoke is thicker so lack of thread and the centre hole would need a bush I might look into the cutting the thread like midlife crisis said if that's not a option then I will have to drop it through the bottom yoke and reweld it
Post by dusty350 on Nov 25, 2019 14:41:21 GMT 1
What are the new yokes off ? Dusty
Post by scooter on Nov 25, 2019 14:51:02 GMT 1
There 20007 fz6 Fazer and rs125 wheels
