Post by ypvs1968 on Nov 24, 2019 18:37:48 GMT 1
Hi
Some years ago, I picked up a set of gears. They've been sat in an oil filled plastic box since.
Memory is a bit hazy now, so I can't remember if both shafts sets were bought together or separately and specifically whether they are LC or YPVS or even one shaft of each.
I'd possibly like to use them now in a set of YPVS crankcases but need to check they are YPVS ones.
Is there a way to identify LC from YPVS gear clusters?
Thanks in advance.
Post by markhoopy on Nov 24, 2019 19:29:21 GMT 1
6th gear is wider on the YPVS gearbox and the output shaft is longer too - this is YPVS
Post by dusty350 on Nov 24, 2019 22:06:08 GMT 1
Post by ypvs1968 on Nov 25, 2019 20:26:23 GMT 1
Many thanks for going to the trouble to post these pictures Dusty!
When it eventually stops raining, I'll get out into the garage and do some comparisons against your info and pics.
Cheers.
