Post by philip on Nov 24, 2019 6:08:45 GMT 1
Some time ago I purchased Hagon Progressive Fork Springs, the standard springs measure 19 1/2" (49 CM) where the Hagon measure 20 3/4"(53cm) is it safe to presume that after 38 years wear and tear have reduced the spring lenght?
Also would it be safe to replace the spring clip with a suitable sized circlip?
Thanks for any infor
Philip
Post by LC_BOTT on Nov 24, 2019 9:24:35 GMT 1
4cm seems like a bit more than normal wear/sag, have a search to see if you can find correct length (prpbably in the manual) any signs of the ends being cut when you look.
You need the spring clips as the originals sit between the cap and the fork leg, so there is a recess in the top that gets covered by the cap, they usually get wet and rust away. Couple of pence from Yamaha??
Post by oldelsieboy on Nov 24, 2019 9:37:16 GMT 1
Some time ago I purchased Hagon Progressive Fork Springs, the standard springs measure 19 1/2" (49 CM) where the Hagon measure 20 3/4"(53cm) is it safe to presume that after 38 years wear and tear have reduced the spring lenght? Also would it be safe to replace the spring clip with a suitable sized circlip? Thanks for any infor Philip OEM spring length should be 497mm OEB
Post by earthman on Nov 24, 2019 9:59:42 GMT 1
Would be interested in the outcome of this, I'm debating on what I should do with the springs in my bike.
Post by veg on Nov 24, 2019 11:27:18 GMT 1
Hagin progressive are a bit longer. I can’t remember the exact difference but I measured them against stock length and was surprised.
Post by JonW on Nov 24, 2019 13:51:07 GMT 1
My Goki AirCaps came with circlips, so it is possible, but as has been said the OEM tops trap the wire clips, so you should really use the correct thing.
tlmark
Post by tlmark on Nov 24, 2019 18:47:36 GMT 1
Yup when I fitted them they were quite a bit longer, made getting the top plug hard work.
Post by philip on Nov 26, 2019 12:35:34 GMT 1
Thanks for the infor much appreciated
Philip
