Post by noonster on Nov 17, 2019 0:52:08 GMT 1
has any one come across where the thread into the frame is worn so the foot hanger bolt wont fully tighten up
Post by bare on Nov 17, 2019 1:02:26 GMT 1
More 'n likely cross threaded than worn out. Not a thread that sees much on / off action. Regardless, either retap larger, maybe fill the thread with weld then retap, or try to fit a threadsert.
Post by shaunthe2nd on Nov 17, 2019 1:29:32 GMT 1
Is this the M10 thread? Yam used M10 fine thread 1.25mm rather than the normal 1.5mm bolt thread if I remember correct and that's why thread was probably damaged at some point in last 37 years.
Post by JonW on Nov 17, 2019 2:55:34 GMT 1
I agree with whats been said above. some sort of helicoil will fix it.
Post by ianboom on Nov 17, 2019 8:52:46 GMT 1
I weld a half but on the back of the threads before I have my frame powder coated just in case.
Post by dusty350 on Nov 17, 2019 9:33:53 GMT 1
I've had a few frames with damaged threads. Easiest fix is a longer bolt with a nyloc on the back. Or repair the thread for a neater repair Dusty
Post by huggy76 on Nov 17, 2019 15:44:13 GMT 1
I had this problem on my 31k frame. Someone in the past has probably wound a normal M10 bolt in. I put a helicoil in mine and it’s been good for the last 10 years.
