Lc2 forks
Nov 11, 2019 18:54:29 GMT 1
via mobile
Post by Dixie Dean on Nov 11, 2019 18:54:29 GMT 1
Hi everyone I’m in the process or rebuilding my lc2 forks While stripping the forks both forks had a spacer in the top,according to the Haynes manual lc2 forks don’t have spacers and any tips when rebuilding the forks ie tools .
Lc2 forks
Nov 11, 2019 19:09:28 GMT 1
via mobile
Post by midlifecrisisrd on Nov 11, 2019 19:09:28 GMT 1
No spacer but they are commonly fitted
Usually 10-20mm
Back in the day we used to pop 2p's in. 6 each side, best 24p mod ever 🤣
Same as dismantelling the bottom bolt tightens better with the spring and fork top fitted
Only "special" tool I use I'd about 2 foot of abs pipe from b and q with one of the glue in straight couplers on the end with some slots cut in it so it can squeeze slightly smaller that I use for driving the seals in
Lc2 forks
Nov 11, 2019 19:34:10 GMT 1
via mobile
Post by Dixie Dean on Nov 11, 2019 19:34:10 GMT 1
Hi my spacers are about 100mm do think I will Need them with Hagon progressive springs any chance of a picture of your B&M tool?
Lc2 forks
Nov 11, 2019 19:40:46 GMT 1
via mobile
Post by midlifecrisisrd on Nov 11, 2019 19:40:46 GMT 1
Hi my spacers are about 100mm do think I will Need them with Hagon progressive springs any chance of a picture of your B&M tool? I'll get a pic Sounds like you have F1/2 springs and spacers in them 🤔 Steve
Lc2 forks
Nov 11, 2019 19:45:33 GMT 1
via mobile
Post by Dixie Dean on Nov 11, 2019 19:45:33 GMT 1
Ok no telling what the previous owner would have done considering the state of the bike 🏍 when I got it thanks.
Post by jon on Nov 11, 2019 19:46:35 GMT 1
Hi my spacers are about 100mm do think I will Need them with Hagon progressive springs any chance of a picture of your B&M tool? My Hagon springs for an F2 did away with the spacer. Jon
Post by midlifecrisisrd on Nov 11, 2019 19:48:02 GMT 1
DIY seal driver Steve
Lc2 forks
Nov 11, 2019 19:50:34 GMT 1
via mobile
Post by Dixie Dean on Nov 11, 2019 19:50:34 GMT 1
Is that 40mm tube?
Lc2 forks
Nov 11, 2019 19:51:36 GMT 1
via mobile
Post by Dixie Dean on Nov 11, 2019 19:51:36 GMT 1
Thanks jon
Lc2 forks
Nov 11, 2019 19:54:21 GMT 1
via mobile
Post by Tobyjugs on Nov 11, 2019 19:54:21 GMT 1
When I did my best to set a pair of LC2 forks up I ended up with 14 mm spacers used with progressive springs. Make unknown. You can read about it in my thread
Advice Needed for putting an RD on a track.
Lc2 forks
Nov 11, 2019 19:55:27 GMT 1
via mobile
Post by midlifecrisisrd on Nov 11, 2019 19:55:27 GMT 1
Think so Its the bigger of the 2 drain sizes And it's the glue together type as the poly stiff is smaller and too soft to whack with a rubber mallet Steve
Lc2 forks
Nov 12, 2019 21:03:21 GMT 1
via mobile
Post by Dixie Dean on Nov 12, 2019 21:03:21 GMT 1
Hi can you tell me how much fork oil lc2 have in them and the best way of measuring the oil
Post by stusco on Nov 12, 2019 21:12:44 GMT 1
Haynes manual and a kitchen jug,mind and give it a good wash before you put it back
Lc2 forks
Nov 16, 2019 21:12:18 GMT 1
via mobile
Post by Dixie Dean on Nov 16, 2019 21:12:18 GMT 1
Lc2 forks
Nov 16, 2019 21:13:28 GMT 1
via mobile
Post by Dixie Dean on Nov 16, 2019 21:13:28 GMT 1
Hi mate diy deal driver very helpful thanks 👍🏻
Lc2 forks
Nov 16, 2019 21:13:55 GMT 1
via mobile
Post by Dixie Dean on Nov 16, 2019 21:13:55 GMT 1
Sealnot deal
Post by stusco on Nov 16, 2019 22:31:35 GMT 1
Lc2 forks
Nov 16, 2019 22:43:05 GMT 1
via mobile
Post by Dixie Dean on Nov 16, 2019 22:43:05 GMT 1
Plastic pipe for pushing oil seals in to forks.
