Post by JonW on Nov 22, 2019 22:51:17 GMT 1
Er... I'm sure. Good to see the airbox in, the KTM has a sizable airbox so that's amazing you managed that.
31K(TM)
Nov 22, 2019 23:38:38 GMT 1
via mobile
Post by urbantangleweed on Nov 22, 2019 23:38:38 GMT 1
Er... I'm sure. Good to see the airbox in, the KTM has a sizable airbox so that's amazing you managed that. Could only just squeeze in the actual air filter unit, there's no airbox as such but once the side panels are on the space under there is probably fairly similar to the volume of the KTM airbox, there's lots of big gaps of course, but the KTM airbox breathes through various vents and the panel gaps make it far from a sealed box so it may well be OK. Time will tell.
Post by JonW on Nov 23, 2019 12:45:51 GMT 1
Agreed the KTM box is pretty 'leaky' and relies on the area under the huge filter more than anything I reckon.
Post by midlifecrisisrd on Nov 23, 2019 13:43:23 GMT 1
That's like a cheese dream 🤣🤣🤣 Steve
Post by urbantangleweed on Nov 23, 2019 22:32:33 GMT 1
That's like a cheese dream 🤣🤣🤣 Steve I really don't think I like it, took me 2 hours to make the brackets too!
31K(TM)
Nov 24, 2019 10:17:35 GMT 1
via mobile
Post by urbantangleweed on Nov 24, 2019 10:17:35 GMT 1
For ease of cooling system plumbing on this, it works far easier to have the flow reversed through the radiator, i.e. bottom hose to radiator top inlet and top hose to radiator bottom inlet. Is this likely to cause any problems? I won't run a 'stat so as far as I can see, it should circulate and cool ok even though it's reversed. Your thoughts gentlemen please? I'll post photos to show the reversed pipework.
Post by urbantangleweed on Nov 24, 2019 10:18:43 GMT 1
Post by urbantangleweed on Nov 24, 2019 10:19:04 GMT 1
31K(TM)
Nov 25, 2019 16:03:00 GMT 1
Post by Deleted on Nov 25, 2019 16:03:00 GMT 1
i'd check the water pump can cope with the extra hosing particularly those 90 fittings, they do create quite a bit of flow loss and the change of direction is the pump now pumping coolant up through the radiator or only pumping up to the top of the radiator
most systems have flow from top to bottom to give the circulating pump static head (i think ive got that right)
31K(TM)
Nov 25, 2019 21:18:04 GMT 1
Post by urbantangleweed on Nov 25, 2019 21:18:04 GMT 1
i'd check the water pump can cope with the extra hosing particularly those 90 fittings, they do create quite a bit of flow loss and the change of direction is the pump now pumping coolant up through the radiator or only pumping up to the top of the radiator most systems have flow from top to bottom to give the circulating pump static head (i think ive got that right) Fair points, I think I'll have to suck it and see, part of my reasoning that it might well be OK is that on the standard set up, the pump has to lift the coolant quite high due to where the rads are on the original bike, on this one, the coolant only has to travel half the height.
Post by JonW on Nov 26, 2019 2:23:30 GMT 1
Also depends on which way the KTM pumps its water, but I think the pump is front right like on the RD/RZ and sucks water from the rad and pumps thru the engine.
if that is the case, then I think a problem is that youre drawing off the hot water (at the top of the rad) instead of the cooler water at the bottom of the rad where its settled as its been cooled by the air running thru the rad.
Post by urbantangleweed on Nov 26, 2019 8:41:05 GMT 1
Also depends on which way the KTM pumps its water, but I think the pump is front right like on the RD/RZ and sucks water from the rad and pumps thru the engine. if that is the case, then I think a problem is that youre drawing off the hot water (at the top of the rad) instead of the cooler water at the bottom of the rad where its settled as its been cooled by the air running thru the rad. I think that is right concerning coolant flow and may cause it to run warmer than usual, something to check when I get it running. If need be, I'll have to plumb it right way round, it would also give me the opportunity to find a more elegant solution.
Post by urbantangleweed on Mar 8, 2020 13:08:42 GMT 1
Not had much inclination to do anything on this over the horrible winter months but spring is on the way so started up again. Bottom engine mount is now in and seems to hold it quite sturdily. Got an exhaust sorted too, no idea if it will work as it comprises a header pipe mated to a standard RD spannie, be interesting to see if it holds the engine back but whatever happens, it should work well enough for preliminary running and to get it MOT'd. I'll get it welded up as soon as a mate of mine can come over to do it.
Post by urbantangleweed on Apr 27, 2020 22:09:23 GMT 1
Lockdown has seen reasonable progress on this over the last couple of weeks, getting bits is hit and miss with the post though, some things arrive in the usual 2 or 3 days, others can take up to a couple of weeks. Ditched the earlier double mudguard idea (must have been drinking too much....) and improved the cooling system plumbing which appears to work well. Anyway, lots more to do but here's a photo of how it is currently.
Post by JonW on Apr 27, 2020 23:25:18 GMT 1
Ohhh looks nice in KTM orange!
Post by urbantangleweed on Apr 29, 2020 16:03:26 GMT 1
Rainy day so been messing about with graphics, just need for a mate of mine to get them done in vinyl now.
Post by urbantangleweed on Apr 29, 2020 16:04:33 GMT 1
Tank graphics
Post by urbantangleweed on Apr 29, 2020 16:05:08 GMT 1
Side panel graphics
Post by urbantangleweed on Apr 29, 2020 16:05:46 GMT 1
Tail unit graphics
Post by JonW on Apr 30, 2020 0:02:07 GMT 1
LOL, too funny Such a unique build. Cant wait to hear what you think it rides like when this C19 is over.
Post by urbantangleweed on Apr 30, 2020 9:02:42 GMT 1
LOL, too funny Such a unique build. Cant wait to hear what you think it rides like when this C19 is over. I've ridden it up and down the drive but only 15 feet or so in first gear, it feels lively! My main concern is how the engine will run with my cobbled up exhaust. Time will tell.
Post by oldbritguy on Apr 30, 2020 10:40:51 GMT 1
Looking really good
Will confuse the hell out of some folk trying to work out what it is 😉
Post by donkeychomp on Apr 30, 2020 21:55:44 GMT 1
Surely the side panel decals are self explanatory... Alex
Post by urbantangleweed on May 4, 2020 19:20:23 GMT 1
Decals done and on the way!
Post by urbantangleweed on May 15, 2020 19:40:32 GMT 1
With a little shed engineering I replaced the dogleg chain slider with a KTM type roller.
Post by midlifecrisisrd on May 15, 2020 20:22:46 GMT 1
Nice job 😎
Post by urbantangleweed on May 16, 2020 22:34:07 GMT 1
Post by JonW on May 17, 2020 6:55:32 GMT 1
Turned out to be a high spec machine in the end. Magura hydraulic clutch, domino throttle etc etc... all gifts from the KTM side of the equation Looks a lot letter than it has any right to really lol. Cant wait to see what you think riding it around.
Post by urbantangleweed on Jun 2, 2020 15:02:33 GMT 1
KTMAHUMPH MOT'd today, straight through, no advisories.
It rides nicely, more vibey compared to a regular 350 and as I suspected, the pipe is strangling the engine somewhat so now need to find someone to make a proper chamber for it but all in all, quite pleased.
