Post by huggy76 on Nov 8, 2019 19:27:07 GMT 1
Could someone measure a good powervalve for the sizes that the bush and the seal run on please. I am looking at making a steel sleeve and new bushes to repair the valves when worn. Thanks
Post by bare on Nov 10, 2019 20:44:39 GMT 1
IF sleeving the valve bearings/surfaces, then it's simple to ream the Bushes to fit the sleeves Doesn't matter what precise size the OEMs were when new. Does it?
Post by huggy76 on Nov 10, 2019 20:59:48 GMT 1
I could ream the bushes to fit but reckon it would be better to make new to remove any wear in the groove that the locating plate fixes in. Also want to get the correct diameter for the castle seal to run on so that I can just buy new, genuine Yamaha seals.
Ruddy
Post by Ruddy on Nov 12, 2019 13:28:47 GMT 1
Does anyone know what the ID of the bushes are and the OD of the valve, or what clearance there should be between the two. Any info greatly appreciated. Thank Steve.
Post by marrcel on Nov 12, 2019 19:39:32 GMT 1
I can measure it tomorrow. I have the pv out at the mo
Ruddy
Post by Ruddy on Nov 15, 2019 0:26:32 GMT 1
I can measure it tomorrow. I have the pv out at the mo Did you have chance to measure the valves/bushes? If nobody knows the sizes can anyone suggest what clearance there should be between the two? Presumably there'll be an amount of expansion when hot.
Post by ianboom on Nov 15, 2019 10:31:20 GMT 1
Post by ianboom on Nov 15, 2019 10:43:45 GMT 1
Ruddy
Post by Ruddy on Nov 15, 2019 14:34:45 GMT 1
Just measured pv & bush fresh out of the bag,nos. Pv shaft dia. is 17.00mm pv bush id. is 17.20mm.Sorry but im a modern metric lad...
taken from that thread, Thanks Ian Steve.
Post by huggy76 on Nov 15, 2019 14:57:20 GMT 1
Thanks guys, that’s a very useful link. I like the idea of the different locating plate on the link from the link if that makes sense. Think it’s Italian but shows some good pics.👍
