Post by mellow on Oct 28, 2019 13:43:45 GMT 1
Hi men. Need some advice. Rd125lc. ๐ The front wheel spacer for between bearings, does the collar go brake disc side? Is mine on far enough?will post pic later๐ Also which bearing do you fit first so correct spacing is achieved? I'm thinking speedo drive side first as there is machined shoulder, then spacer, then press brake side one until it touches spacer tube??๐ค๐ Thanks๐๐
Post by LC_BOTT on Oct 28, 2019 16:02:35 GMT 1
Sounds a logical way to do it to me, aren't both sides of the wheel 'shouldered' I also slip the wheel spindle through when seating the second bearing, in an attempt to line-up the spacer correctly.
Post by mellow on Oct 28, 2019 17:14:22 GMT 1
Hi. Yes they are both shouldered. One side very deep, the speedo drive not so, just about the width of the bearing. Hence why i thought it be best to fit speedo bearing first or the drive may not sit in enough.? Here is the spacer tube. Do you think the collar is on far enough? Thanks for reply
