Post by Header on Oct 23, 2019 13:56:05 GMT 1
folks where can i buy the honing tool for the cylinder apart from the states takes too long to ship, i can get the 3 legged one easy but i was told to get the one like a brush all little balls on it anywhere in ireland or england have them ?
Post by stusco on Oct 23, 2019 14:18:29 GMT 1
I used spirit of salts ( drain cleaner) it dissolves the alloy leavings the steel on the liner www.dropbox.com/s/o4y2qq9ndbkvpi1/image0.jpeg?dl=0dabbed it on with a cotton bud and watched the alloy bubble then washed it off took about half an hour to clean up a cylinder
Post by dave1963 on Oct 23, 2019 15:06:21 GMT 1
If your trying to remove ali from bores brick acid is very good i have used it a couple of times
Post by Deleted on Oct 23, 2019 16:59:40 GMT 1
wouldn't put brick acid anywhere near bores, HCl and steel don't like each other
Post by dave1963 on Oct 23, 2019 19:00:06 GMT 1
A good tunning person told me that what he dose and i have had no problems so far
Post by shandyboy on Oct 23, 2019 19:42:50 GMT 1
Your fine as long a it is inhibited Acid then coat will oil straight away
Post by Header on Oct 23, 2019 20:06:26 GMT 1
Thanks lads will try spirit of salts drain cleaner tomorrow
Post by muttsnuts on Oct 23, 2019 21:09:51 GMT 1
these guys do them --> www.pacehigh.co.uk/?gclid=EAIaIQobChMIt5W_vpez5QIVUEHTCh2uAwgyEAAYASAAEgIK5fD_BwE not cheap mind, I've used ball honers for years, but recently got some new honers which work really well - whereabouts are you, if your close by, just pop round and I'll hone them for you Using brick acid is fine to dissolve the ali, just be sure as stated to wash it off quickly and then coat the bores in oil
Post by steven on Oct 24, 2019 8:27:47 GMT 1
Post by bare on Oct 26, 2019 1:01:54 GMT 1
Seriously? Order/wait for the US made Ball hone. Care is selecting correct size though, It Works 'exactly' as claimed ie; perfectly. Only caveat being: follow instructions and Only use it for the specified number of seconds. More is not better. Bit of an annoyance that few seconds of actual use.. after having to wait interminably for delivery though.
