Lc2 forks
Oct 19, 2019 12:34:42 GMT 1
via mobile
Post by Dixie Dean on Oct 19, 2019 12:34:42 GMT 1
Hi guys having trouble removing bottom bolt from forks have tried a wooden dowel down the tube but unable to hold the damper rod any help please.
Post by JonW on Oct 19, 2019 12:43:26 GMT 1
reassemble the fork springs and cap. Wind away with allen key. if that fails, borrow a cheap impact gun for DIY work, the ones in the sets with the drills will usually do this easily, you dont need a proper impact socket gun.
Lc2 forks
Oct 19, 2019 13:17:37 GMT 1
via mobile
Post by midlifecrisisrd on Oct 19, 2019 13:17:37 GMT 1
What jonw said 😁
Post by Dixie Dean on Oct 19, 2019 13:23:30 GMT 1
Thanks 1 came loose but the other one keeps turning.
Lc2 forks
Oct 19, 2019 15:13:18 GMT 1
via mobile
Post by Dixie Dean on Oct 19, 2019 15:13:18 GMT 1
Hi guys ratchet strap fork under pressure with spring in and what do you know bolt undoes thanks
Post by JonW on Oct 20, 2019 7:06:56 GMT 1
Glad youre sorted. I never understand why the manuals tell you to take the spring out and use a special tool when doing it under pressure always works.
Lc2 forks
Oct 20, 2019 11:33:13 GMT 1
via mobile
Post by Dixie Dean on Oct 20, 2019 11:33:13 GMT 1
Hi guys any body know how to Get lc2 fork bottoms back to original finish?
Post by steeley on Oct 20, 2019 12:59:54 GMT 1
Hi guys any body know how to Get lc2 fork bottoms back to original finish? Hi ,i had some success with a stainless steel brush .
Lc2 forks
Oct 21, 2019 8:50:24 GMT 1
via mobile
Post by midlifecrisisrd on Oct 21, 2019 8:50:24 GMT 1
Best way is to polish then a red scotchbrite pad and acf50
Post by abar121 on Oct 21, 2019 15:08:33 GMT 1
Best way is to polish then a red scotchbrite pad and acf50 Steve Great. Do you degrease / lacquer afterwards? Also agree about undoing the damper rod bolt when assembled. I had one that still spun. An impact wrench did the job.
Lc2 forks
Oct 21, 2019 16:05:23 GMT 1
via mobile
Post by midlifecrisisrd on Oct 21, 2019 16:05:23 GMT 1
I leave bare and just keep wiping with acf
If you lacquer them corrosion will usually creep under the lacquer
Post by abar121 on Oct 21, 2019 16:20:49 GMT 1
Yeah, had that happen under lacquer.
I just polish them now, but it upsets the anoraks.
