Post by mak595 on Oct 16, 2019 11:52:03 GMT 1
Guys, on my F1 im tring to suss out the loom routine at the front, i assume it runs on the left side due to the plastic cover over the headlight bracket has i mounding for it, does it then run between the frame spars where the plastic triangle trims go or under the steering stem, close to the rad?
Post by Deleted on Oct 17, 2019 6:37:37 GMT 1
This will be good info for me too
Eventually
Post by Yogi on Oct 17, 2019 17:39:47 GMT 1
The loom exits on the left side at the front of the plastic infill panel then between the forks,hereβs some pics that should help Matt π»
Post by Deleted on Oct 18, 2019 6:37:56 GMT 1
Thanks Yogi
Where on Xaviers site did you find it, I thought it was there somewhere
Post by Yogi on Oct 18, 2019 6:49:33 GMT 1
Hi Howard
Download,,,Technical spec then F1 service manual
Matt π
Post by mak595 on Oct 19, 2019 13:47:00 GMT 1
Thanks Matt, perfect
Post by Deleted on Oct 19, 2019 16:28:16 GMT 1
yep +1 for Matt
stoney
Post by stoney on May 13, 2020 14:04:19 GMT 1
Download,,,Technical spec then F1 service manual Matt π Just what I was looking for as well. Cheers.
