Post by paulincayman on Oct 14, 2019 16:24:25 GMT 1
Hi , all , Been looking at my two sets of 29L crankcases trying to decide which one is better for the build, the better of the two is marked 29L-00, but it is slightly different to the other ( later?) set marked 29L-01 in that it has a rectangular cut out in the bottom of the lower case right below the neutral switch cover , it is perfectly formed and there is no sign of damage anywhere so I'm assuming it was made that way . The later 29L-01 case has that hole filled in , you can still see the faint outline of where the mould was modified . Anyone has a theory why the earlier one had the cutout and then why it was filled in ,. Really asking because I want to use the earlier case and was considering filling in the cut out. TIA Paul
Post by midlifecrisisrd on Oct 14, 2019 16:57:16 GMT 1
The cut outs are a mystery
I've seen them on early and later cases
Do they have the indent on the upper edge where the RH carb bowl would be
Post by paulincayman on Oct 15, 2019 2:39:20 GMT 1
Don't see anything like a dimple/indent. These are 31k cases if it makes a difference. I think I'll fill it in anyway.
Post by JonW on Oct 15, 2019 3:27:54 GMT 1
I thought it was there as a drain of some sort, for rainwater etc
Post by JonW on Oct 15, 2019 3:39:14 GMT 1
A thought: Do the AC cases have it?
Post by pdxjim on Oct 15, 2019 3:53:41 GMT 1
I thought it was there as a drain of some sort, for rainwater etc Exactly what I was gonna say ... place for the rainwater and excess chain lube to drain out.
Post by paulincayman on Oct 15, 2019 13:35:41 GMT 1
If that were the reason then why blank it off in later versions? Scratching my head.
Post by JonW on Oct 15, 2019 22:39:29 GMT 1
Might have cost 10c more to tidy it up when out of the mould, or they found it was more likely to crack if it got hit by a stone or the bike got dropped, let alone what might happen when the chain snaps.
Post by midlifecrisisrd on Oct 15, 2019 22:41:53 GMT 1
I reckon it was to stop you having to get this done after the weak bit gets broken Steve
Post by paulincayman on Oct 16, 2019 3:37:45 GMT 1
Well that seems sensible..dev filling mine in . Thanks all.
Post by JonW on Oct 16, 2019 4:43:08 GMT 1
I doubt youre going to snap a chain Paul, you'll look after it unlike the yoofs of old
Post by dusty350 on Oct 16, 2019 9:35:31 GMT 1
Aircooled engines had the cut out too; 1 by dusty miller, on Flickr If it were me, I would leave as is. I've not had an engine with that bit broken off before when it's been cut out. You are more likely to break the top part of the casing off with a snapped chain ( had a couple of those cases with damage) Dusty
Post by paulincayman on Oct 16, 2019 11:50:27 GMT 1
Sage like as always Dusty..leave as then. Case closed (left open ).
