Post by zig on Oct 10, 2019 21:29:15 GMT 1
as a noob i'm very interested in anyone that has done either or both conversions ?? what are the pro's and con's?? what has the Banshee over the Athena?? are they both suitable for everyday use and run's & what about reliability??
Thanks Guy's
ZiG
Post by JonW on Oct 11, 2019 0:16:09 GMT 1
Im not sure what a 'Banshee conversion' is, but plenty of info on Athena on here, play with the search.
I did a Primer article on my website about big bores if youre interested, its under 'upgrades' on 2smoke.com
Post by jon on Oct 11, 2019 7:53:51 GMT 1
If by banshee, you mean OEM, then donβt bother.
Post by markhoopy on Oct 11, 2019 10:21:39 GMT 1
A Banshee conversion would involve adding two more wheels. Might as well buy a car tbh.
Post by rigga on Oct 11, 2019 14:14:33 GMT 1
Forget banshee, as said its just a variation fitted to a quad, but it shares the bottom end with a ypvs, which you do want, then you can add the top end of your choice, but that alone require careful planning, as each has pros and cons, Athena, cheetah, cub, plus then on top of that dedicated exhausts for the stubs, bigger carbs to feed the motor, programmable ignitions to get the best out of it ..... Look at some of the build threads for an idea of what works well, and the cost involved, good thing is that a good few on here have gone down this route, and all with gladly give good advise.
If I could find a decent priced bottom end I'd consider it myself.
Post by wallcraft on Oct 11, 2019 17:41:22 GMT 1
Pretty sure the banshee has closer gears which will obviously make it accelerate a lot more aggressively, may not be a bad thing, depends on what you want π€
Post by headcoats on Oct 11, 2019 20:09:06 GMT 1
I'm doing just the Athena top end so a 392 conversion Nearing the end now so no experience at all on it running LOL
But I do find it baffling how many folks have had theirs and then you hear nothing about what they are like on the road etc !
I think they must be a pain in the arse to ride as no one comes on and says they f##kin rip and couldn't stop myself laughing everytime I take it out LOL
Post by zig on Oct 12, 2019 8:47:40 GMT 1
I'm doing just the Athena top end so a 392 conversion Nearing the end now so no experience at all on it running LOL But I do find it baffling how many folks have had theirs and then you hear nothing about what they are like on the road etc ! I think they must be a pain in the arse to ride as no one comes on and says they f##kin rip and couldn't stop myself laughing everytime I take it out LOL exactly my thoughts 'headcoats' hence the thread....i couldn't find anything on here apart from some really nice pictures as regards what they are like on the road
Post by rigga on Oct 12, 2019 8:54:49 GMT 1
Message Dave (muttsnutts), he has experience of building such conversions, and one of his was recently featured in practical sportsbikes magazine, with a test feature, he will be able to let you know what they are like to live with.
Post by headcoats on Oct 12, 2019 9:05:33 GMT 1
I'll let you know , warts and all but you may have to wait a bit as I'm doing a super slow build ! Plus weather is on the turn
One thing I'm worried about is the traction out the powerband and how much of a lull/flat spot before the band kicks in
There was someone who had a 421 on the road and didn't like it all and prefered a tuned YPVS engine which can make nearly 70 BHP
Here's a link
rdlccrazy.proboards.com/thread/48809/421cc-pros-cons
Post by 2banger on Oct 13, 2019 16:35:55 GMT 1
Pretty sure the banshee has closer gears which will obviously make it accelerate a lot more aggressively, may not be a bad thing, depends on what you want π€ π
Post by Tobyjugs on Oct 13, 2019 16:54:58 GMT 1
Here are the gear ratios for the two bikes plus the Nova ratios.
Gear YPVS gears YPVS gear ratio Nova gear ratio Banshee gears Banshee gear ratio 1st 36/14 2.571 1.889 32/13 2.461* 2nd 32/18 1.777* 1.450 29/16 1.812 3rd 29/22 1.318* 1.227 27/18 1.5 4th 26/24 1.083* 1.083 25/20 1.25 5th 25/26 0.961* 1.000 23/22 1.045 6th 24/27 0.888 0.923 21/24 0.875*
Post by Tobyjugs on Oct 13, 2019 17:04:07 GMT 1
A mixture of both might be good
Post by 2banger on Oct 13, 2019 20:20:15 GMT 1
Good idea
Post by muttsnuts on Oct 14, 2019 9:03:18 GMT 1
My RS421 runs a mixed gearbox, works well, but its due an overhaul now, nowt to do with the mixed setup, more to do with the abuse its had both on the road and the dyno !
