Post by oldbritguy on Oct 9, 2019 22:20:08 GMT 1
Hi Folks I am in the process of wiring the ignitech unit into my 31k loom and the supplied instruction says to splice the power feed to the unit into an existing switched live wire (usaually brown wire in the loom) Since the ignitech unit dispenses with the PV servo control module, I was going to use the switched feed to that instead. The PV system has it's own fuse in the fuse box which is 5A. Question is will 5A be ok for operating the ignitech unit and also the PV servo, or should I up the amperage? What do the rest of you have?
John
Post by midlifecrisisrd on Oct 10, 2019 7:53:10 GMT 1
5a is fine
Done it 3 times now with no problem
Post by oldbritguy on Oct 10, 2019 9:58:56 GMT 1
Thats great Steve and thanks for the reply. 5A it will be John
