Levers
Sept 23, 2019 15:14:59 GMT 1
via mobile
Post by bernardo on Sept 23, 2019 15:14:59 GMT 1
Does anyone know of an adjustable span lever that will fit a standard 4lo front brake mastercylinder? I have a problem with the fingers on my right hand. or should I get a master cylinder from a yzf125?
Thanks
Bernard
Levers
Sept 24, 2019 22:37:41 GMT 1
Post by 4l04ever on Sept 24, 2019 22:37:41 GMT 1
You can get easier pull by using a smaller master cylinder at the expense of lever travel (less force, more travel) Standard 4L0 = 5/8" TDR250 = 14mm LC250 = 1/2" / 12.7mm YBR125 = 11mm You can get long span adjustable levers from China for much cheapness... www.ebay.co.uk/itm/Aikeec-Fit-Yamaha-RD-350-LC-1980-1981-Motor-Short-Long-2-PCS-Brake-Clutch-Levers/282726228852Don't get the short ones as they make the pull harder. The clutch lever has to be filed a little to fit in the bracket. These levers are interchangeable in all the above mentioned master cylinders. Where are you based, as someone local may have one you can try before you invest in a new one?
Levers
Sept 25, 2019 10:25:10 GMT 1
via mobile
Post by bernardo on Sept 25, 2019 10:25:10 GMT 1
Thanks for that. Just what I needed to know. My problem isn't so much the effort but I can't straighten my fingers so I need a lever closer to the bar. I'm in the west of Ireland so a swap isn't feasible, but now I have options.
Thanks again Bernard
Post by oldelsieboy on Sept 25, 2019 13:03:18 GMT 1
I have a pair of similar levers to the ones in 4L04ever's link. FOC just pay the postage. OEB
Levers
Sept 25, 2019 15:51:22 GMT 1
via mobile
Post by bernardo on Sept 25, 2019 15:51:22 GMT 1
I'll take you up on that. I still have the mick Abbey pipes I bought from you years ago. I'll send you a pm
Thanks
Bernard
Levers
Sept 25, 2019 17:00:27 GMT 1
Post by oldelsieboy on Sept 25, 2019 17:00:27 GMT 1
I'll take you up on that. I still have the mick Abbey pipes I bought from you years ago. I'll send you a pm Thanks Bernard Don't think I've ever owned any Mick Abbey pipes No pm received. OEB
